simulaton of pre-spary or initial spray with sprayFoam
Like Tree2Likes
  • 1 Post By saeedshayae
  • 1 Post By mturcios777
Old   January 23, 2015, 12:22
Default simulaton of pre-spary or initial spray with sprayFoam
saeed
saeedshayae is on a distinguished road
Hello CFDmans,
As you know,spray of the swirl injector has been divided into two parts, 1-pre-spray or initial spray(transient behavior) and 2- main spray
(steady-state behavior).
The pre-spray is formed due to the inside structure of the swirl injector. It is believed that the initial spray slug is formed during the initial stage of the injection when the angular momentum of liquid within the injector passages has not yet been fully built up.(from Experimental and numerical study of high-pressure-swirl injector sprays in a direct injection gasoline engine, J Gao et al. ,2005)
My question is how we can simulate this (pre-spay) using sprayfoam .I have attached some figures of pre-spay.
Many thanks in advance.
Regards,
Saeed
Andrew_Sm likes this.
saeedshayae is offline   Reply With Quote
Old   January 23, 2015, 14:34
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
A very rough solution would be to use two sprays, but you would need to calculate the relative amounts of each spray. Is there any literature on modelling these types of spray. Otherwise you would have to resolve the internal spray geometry.
saeedshayae likes this.
mturcios777 is offline   Reply With Quote
Old   January 24, 2015, 07:51
saeed
yes,there is. for example in these three attached files pre-spray and main spray simulated, but i don't know how...
1- http://www.4shared.com/file/p1-586KF...erian-Lag.html
2- http://www.4shared.com/office/2ljgc9..._and_nume.html
3- http://www.4shared.com/office/M3IAnz...Spray_Sim.html
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
