January 14, 2015, 16:43 |
pipe inside a closed domain
larry
Rep Power: 11 |
Hello OpenFOAM community,
I want to model the following case and I need some opinions from you regarding the necessary steps for running this case. Please see also attached figure! A brief description of the problem is a pipe inside a closed domain. Hot air enters from the inlet of the pipe and leaves from the outlet of the pipe. This outlet is an internal face of the domain. How can I treat this problem if I don't care (for the moment) about the heat losses from the pipe walls. 1. How to deal with the outlet and the pipe walls which are internal surfaces of my domain? 2.What other dictionaries are necessary (createPatchDict?) 3. How to include pipe walls and outlet in SHMDict? Can you please give me some hints/key points concerning my case. Or better if there is any tutorial (e.x circular region inside another region) that has a generic similarity with my case so I can study it? Thanks. Chris Last edited by christos; January 16, 2015 at 05:26. Reason: better description of problem |
January 17, 2015, 18:09 |
larry
Rep Power: 11 |
Ok I got it!. For those interested to know a workaround is to make the internal outlet as "shadow".
Best regards, Chris |
buoyantsimplefoam, hotroom, pipe |
Problems about phase-change simulation inside a heat pipe | 6863523 | FLUENT | 7 | October 14, 2014 10:07 |
How to simulate a simple fan inside a room ? | rafiktharwat | CFX | 10 | September 23, 2014 02:51 |
[DesignModeler] POROUS Media inside a pipe geometry creation | gauravchauhan | ANSYS Meshing & Geometry | 0 | April 12, 2014 04:15 |
Rotating Pipe inside a stationary pipe | Richy | STAR-CCM+ | 3 | February 7, 2013 04:10 |
Hydrogen concentration inside the battery room | mazhar1613 | ANSYS | 0 | August 15, 2011 02:31 |
