January 28, 2020, 05:53 |
mpirun -np error
Ilhwan Yeo
Rep Power: 6 |
hello
I am a mew FOAM user. I have a some problem. This is error message. I did connect all nodes and shared OpenFOAM-v1912 files. please help me. [2phase@knl001 depthCharge3D]$ mpirun -hostfile machines.txt -np 60 -compressibleInterFoam -parallel ---------------------------------------------------------------------------- Open MPI has detected that a parameter given to a command line option does not match the expected format: Option: np Param: -parallel This is frequently caused by omitting to provide the parameter to an option that requires one. Please check the command line and try again. ---------------------------------------------------------------------------- |
January 28, 2020, 17:53 |
Svetlana Tkachenko
Rep Power: 14 |
Remove the '-' before 'compressibleInterFoam' ?
January 28, 2020, 19:26 |
Ilhwan Yeo
Rep Power: 6 |
Thank you! but, another error message comes out
bash: orted: command not found -------------------------------------------------------------------------- ORTE was unable to reliably start one or more daemons. This usually is caused by: * not finding the required libraries and/or binaries on one or more nodes. Please check your PATH and LD_LIBRARY_PATH settings, or configure OMPI with --enable-orterun-prefix-by-default * lack of authority to execute on one or more specified nodes. Please verify your allocation and authorities. * the inability to write startup files into /tmp (--tmpdir/orte_tmpdir_base). Please check with your sys admin to determine the correct location to use. * compilation of the orted with dynamic libraries when static are required (e.g., on Cray). Please check your configure cmd line and consider using one of the contrib/platform definitions for your system type. * an inability to create a connection back to mpirun due to a lack of common network interfaces and/or no route found between them. Please check network connectivity (including firewalls and network routing requirements). -------------------------------------------------------------------------- |
January 28, 2020, 19:48 |
Svetlana Tkachenko
Rep Power: 14 |
From this thread ([OMPI users]) environment variables need to be set in bashrc for non-interactive logins, e.g. at the top of the bashrc file. Do you have this?
Mike also gave helpful troubleshooting tips at this forum post. |
January 28, 2020, 20:44 |
#5 | |
Ilhwan Yeo
Rep Power: 6 |
what means about "non-interactive logins"? I installed OF in shared home. and I set correct path.. |
January 28, 2020, 21:24 |
Svetlana Tkachenko
Rep Power: 14 |
1. Are all processes expected to run on the same computer or on different ones? If on different ones, the child processes will need to log in to the remote computer without you. This is not interactive.
2. How did you set the path? Thanks, |
January 28, 2020, 22:02 |
#7 | |
Ilhwan Yeo
Rep Power: 6 |
export PATH=$PATH:/usr/local/opt/openmpi/bin export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/opt/openmpi/lib but I installed openmpi-1.10.7 in Thrid party-v1912. so do I write the path differently? for example, export PATH=$PATH:/home/2phase/OpenFOAM/ThridParty-v1912/openmpi-1.10.7/bin export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/2phase/OpenFOAM/ThridParty-v1912/openmpi-1.10.7/lib hanks for your help |
January 28, 2020, 22:59 |
Svetlana Tkachenko
Rep Power: 14 |
I would suggest to put these two lines at the top (not at the bottom) of your bashrc.
January 28, 2020, 23:04 |
#9 |
Ilhwan Yeo
Rep Power: 6 |
January 30, 2020, 20:10 |
#10 |
Svetlana Tkachenko
Rep Power: 14 |
I would suggest to follow Mike's troubleshooting steps which I linked earlier, and post the results here.
April 25, 2021, 08:05 |
#11 | |
cyou
Rep Power: 14 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
