A question on the PIMPLE algorithm
Old   February 10, 2015, 04:45
Default A question on the PIMPLE algorithm
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
I am running an incompressible simulation using PIMPLE. I noticed something with the p residuals which I can't explain to myself:
The initial residual for p decreases over the PIMPLE iterations. However, the initial residual of the last iteration is of the same order of magnitude as the initial residual at the beginning of the PIMPLE iteration.
Why is this the case?
From the code I see nothing that is done differently at the last iteration (except solving for turbulence, but that happens after solving for p anyway. So that might not be the reason.)
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 3.60231e-05, Final residual = 1.66706e-09, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.342611, Final residual = 3.12937e-05, No Iterations 17
GAMG:  Solving for p, Initial residual = 0.00752642, Final residual = 6.27839e-07, No Iterations 16
time step continuity errors : sum local = 1.37565e-12, global = -2.03189e-13, cumulative = -1.55453e-09
PIMPLE: iteration 2
DILUPBiCG:  Solving for Ux, Initial residual = 0.000179105, Final residual = 4.61726e-08, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0170125, Final residual = 1.33717e-06, No Iterations 22
GAMG:  Solving for p, Initial residual = 0.0023444, Final residual = 2.1267e-07, No Iterations 16
time step continuity errors : sum local = 4.58019e-13, global = -6.99882e-14, cumulative = -1.5546e-09
PIMPLE: iteration 3
DILUPBiCG:  Solving for Ux, Initial residual = 5.00896e-05, Final residual = 4.90796e-08, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0047698, Final residual = 3.81808e-07, No Iterations 20
GAMG:  Solving for p, Initial residual = 0.000571794, Final residual = 4.58333e-08, No Iterations 16
time step continuity errors : sum local = 9.82129e-14, global = -1.57202e-14, cumulative = -1.55461e-09
PIMPLE: iteration 4
DILUPBiCG:  Solving for Ux, Initial residual = 1.71822e-05, Final residual = 2.14214e-10, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.00145923, Final residual = 1.36203e-07, No Iterations 18
GAMG:  Solving for p, Initial residual = 0.000143427, Final residual = 1.27477e-08, No Iterations 18
time step continuity errors : sum local = 2.72637e-14, global = -5.41738e-15, cumulative = -1.55462e-09
PIMPLE: iteration 5
DILUPBiCG:  Solving for Ux, Initial residual = 6.04597e-06, Final residual = 7.98942e-10, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.000479671, Final residual = 4.53569e-08, No Iterations 17
GAMG:  Solving for p, Initial residual = 4.41661e-05, Final residual = 8.06229e-09, No Iterations 15
time step continuity errors : sum local = 1.7232e-14, global = -3.20335e-15, cumulative = -1.55462e-09
PIMPLE: iteration 6
DILUPBiCG:  Solving for Ux, Initial residual = 3.72214e-06, Final residual = 1.18203e-09, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.327238, Final residual = 3.2432e-05, No Iterations 16
GAMG:  Solving for p, Initial residual = 0.0132261, Final residual = 8.92727e-09, No Iterations 41
time step continuity errors : sum local = 1.61865e-14, global = 2.78977e-15, cumulative = -1.55462e-09
DILUPBiCG:  Solving for epsilon, Initial residual = 3.86725e-06, Final residual = 4.98789e-10, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 2.39725e-06, Final residual = 3.44058e-10, No Iterations 1
PIMPLE: converged in 6 iterations
Note: I removed some output from solving for U (the dots).
GerhardHolzinger is offline   Reply With Quote
Old   February 11, 2015, 19:53
Default pimpleFoam : last pimple loop residual ?
Uyan is on a distinguished road
Hi Gerhard,
I have the same problem with my pimpleFoam residuals, did you find an explanation for this?
Thank you.
Uyan is offline   Reply With Quote
Old   February 12, 2015, 17:03
Joachim Herb
jherb is on a distinguished road
I think the "problem" is that for the last iteration, no underrelaxation is done. This means that the (non-underrelaxed) result for U is used in the p equation. Then the result of the previous iteration of p is not fitting anymore.
jherb is offline   Reply With Quote
Old   February 13, 2015, 04:21
Gerhard Holzinger
I chose this relaxation factors in fvSolution
relaxationFactors
    equations
        "(k|epsilon|omega)"        0.6;
        p                        0.4;
        U                        0.6;
Old   February 13, 2015, 06:49
Blanco
Blanco is on a distinguished road
I'm not using pimpleFoam actually but if I remember well no underrelaxation is done on the last iteration, that's why we have this behavior, because we have to keep time consistency therefore we can't underrelax the solution from the "inner" loop to the "outer" loop. But we can play with nCorrectors to perform more "outer" loop in the pimple scheme if I'm not wrong.
From an old tut case I have:
PIMPLE
    nNonOrthogonalCorrectors 0;
    nCorrectors          3; //1-3
    nOuterCorrectors   50; //
relaxationFactors
    fields
        p      0.3;
        pFinal   1;
    equations
        "U|k|epsilon"     0.3;
        "(U|k|epsilon)Final"   1;
Blanco is offline   Reply With Quote
pimple, residuals
SIMPLE algorithm SamR Main CFD Forum 19 April 26, 2019 13:06
On the PIMPLE algorithm vkrastev OpenFOAM Running, Solving & CFD 7 April 16, 2012 11:13
Question regarding the F2F particle tracking algorithm implementation. andrewryan OpenFOAM 2 October 22, 2009 01:55
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
SIMPLER Algorithm question Erik Main CFD Forum 1 May 23, 2004 03:57
