February 10, 2015, 04:45 |
A question on the PIMPLE algorithm
Gerhard Holzinger
Rep Power: 28 |
I am running an incompressible simulation using PIMPLE. I noticed something with the p residuals which I can't explain to myself:
The initial residual for p decreases over the PIMPLE iterations. However, the initial residual of the last iteration is of the same order of magnitude as the initial residual at the beginning of the PIMPLE iteration. Why is this the case? From the code I see nothing that is done differently at the last iteration (except solving for turbulence, but that happens after solving for p anyway. So that might not be the reason.) Code:
PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 3.60231e-05, Final residual = 1.66706e-09, No Iterations 2 ... GAMG: Solving for p, Initial residual = 0.342611, Final residual = 3.12937e-05, No Iterations 17 GAMG: Solving for p, Initial residual = 0.00752642, Final residual = 6.27839e-07, No Iterations 16 time step continuity errors : sum local = 1.37565e-12, global = -2.03189e-13, cumulative = -1.55453e-09 PIMPLE: iteration 2 DILUPBiCG: Solving for Ux, Initial residual = 0.000179105, Final residual = 4.61726e-08, No Iterations 1 ... GAMG: Solving for p, Initial residual = 0.0170125, Final residual = 1.33717e-06, No Iterations 22 GAMG: Solving for p, Initial residual = 0.0023444, Final residual = 2.1267e-07, No Iterations 16 time step continuity errors : sum local = 4.58019e-13, global = -6.99882e-14, cumulative = -1.5546e-09 PIMPLE: iteration 3 DILUPBiCG: Solving for Ux, Initial residual = 5.00896e-05, Final residual = 4.90796e-08, No Iterations 1 ... GAMG: Solving for p, Initial residual = 0.0047698, Final residual = 3.81808e-07, No Iterations 20 GAMG: Solving for p, Initial residual = 0.000571794, Final residual = 4.58333e-08, No Iterations 16 time step continuity errors : sum local = 9.82129e-14, global = -1.57202e-14, cumulative = -1.55461e-09 PIMPLE: iteration 4 DILUPBiCG: Solving for Ux, Initial residual = 1.71822e-05, Final residual = 2.14214e-10, No Iterations 2 ... GAMG: Solving for p, Initial residual = 0.00145923, Final residual = 1.36203e-07, No Iterations 18 GAMG: Solving for p, Initial residual = 0.000143427, Final residual = 1.27477e-08, No Iterations 18 time step continuity errors : sum local = 2.72637e-14, global = -5.41738e-15, cumulative = -1.55462e-09 PIMPLE: iteration 5 DILUPBiCG: Solving for Ux, Initial residual = 6.04597e-06, Final residual = 7.98942e-10, No Iterations 2 ... GAMG: Solving for p, Initial residual = 0.000479671, Final residual = 4.53569e-08, No Iterations 17 GAMG: Solving for p, Initial residual = 4.41661e-05, Final residual = 8.06229e-09, No Iterations 15 time step continuity errors : sum local = 1.7232e-14, global = -3.20335e-15, cumulative = -1.55462e-09 PIMPLE: iteration 6 DILUPBiCG: Solving for Ux, Initial residual = 3.72214e-06, Final residual = 1.18203e-09, No Iterations 2 ... GAMG: Solving for p, Initial residual = 0.327238, Final residual = 3.2432e-05, No Iterations 16 GAMG: Solving for p, Initial residual = 0.0132261, Final residual = 8.92727e-09, No Iterations 41 time step continuity errors : sum local = 1.61865e-14, global = 2.78977e-15, cumulative = -1.55462e-09 DILUPBiCG: Solving for epsilon, Initial residual = 3.86725e-06, Final residual = 4.98789e-10, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 2.39725e-06, Final residual = 3.44058e-10, No Iterations 1 PIMPLE: converged in 6 iterations |
February 11, 2015, 19:53 |
pimpleFoam : last pimple loop residual ?
Rep Power: 12 |
Hi Gerhard,
I have the same problem with my pimpleFoam residuals, did you find an explanation for this? Thank you. |
February 12, 2015, 17:03 |
Joachim Herb
Rep Power: 21 |
I think the "problem" is that for the last iteration, no underrelaxation is done. This means that the (non-underrelaxed) result for U is used in the p equation. Then the result of the previous iteration of p is not fitting anymore.
February 13, 2015, 04:21 |
Gerhard Holzinger
Rep Power: 28 |
I chose this relaxation factors in fvSolution
relaxationFactors { equations { "(k|epsilon|omega)" 0.6; p 0.4; U 0.6; } } |
February 13, 2015, 06:49 |
Blanco
I'm not using pimpleFoam actually but if I remember well no underrelaxation is done on the last iteration, that's why we have this behavior, because we have to keep time consistency therefore we can't underrelax the solution from the "inner" loop to the "outer" loop. But we can play with nCorrectors to perform more "outer" loop in the pimple scheme if I'm not wrong. From an old tut case I have: Code:
PIMPLE { nNonOrthogonalCorrectors 0; nCorrectors 3; //1-3 nOuterCorrectors 50; // relaxationFactors { fields { p 0.3; pFinal 1; } equations { "U|k|epsilon" 0.3; "(U|k|epsilon)Final" 1; } } |
pimple, residuals |
SIMPLE algorithm | SamR | Main CFD Forum | 19 | April 26, 2019 13:06 |
On the PIMPLE algorithm | vkrastev | OpenFOAM Running, Solving & CFD | 7 | April 16, 2012 11:13 |
Question regarding the F2F particle tracking algorithm implementation. | andrewryan | OpenFOAM | 2 | October 22, 2009 01:55 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | FLUENT | 0 | April 13, 2007 23:17 |
SIMPLER Algorithm question | Erik | Main CFD Forum | 1 | May 23, 2004 03:57 |
