rhoSimpleFoam crashes after thousands of iterations |
February 11, 2015, 05:57 |
Rep Power: 13 |
I'm trying to simulate the flow between an inner rotating cone and an outer stationary cone for my master thesis. My Geometry is a small "wedge" of 7.5° with cyclicAMI-boundary conditions at both sides. I use a totalPressure condition at the inlet and a massflow outlet condition. In the picture below you cann see, that the residuals start rising again after a few hundred iterations, and that they start oscillating after a few thousand iterations. And finally, a few hours after the osciallations started the simulation chrashes. The little "peaks" after 1000 iteratins originate from a change in the boundary conditions: In order to get a stable simulation I have to start with a pressure driven flow. Only after the flow has settled I can switch to the massflow boundary condition. My boundary conditions: Pressure-field: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 362900; boundaryField { INLET { type totalPressure; gamma 1.4; p0 uniform 362900; // total pressure 362900 value uniform 362900; } OUTLET { type zeroGradient; } SYM_1_OBEN { type cyclicAMI; } SYM_1_UNTEN { type cyclicAMI; } SYM_2_OBEN { type cyclicAMI; } SYM_2_UNTEN { type cyclicAMI; } MOVINGWALL_OBEN { type zeroGradient; } MOVINGWALL_UNTEN { type zeroGradient; } BOHRUNG { type zeroGradient; } WALL_OBEN { type zeroGradient; } WALL_UNTEN { type zeroGradient; } PLENUMWALL { type zeroGradient; } KEIL { type zeroGradient; } GAP_S { type zeroGradient; } GAB_W { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { INLET { type zeroGradient; } OUTLET { type flowRateInletVelocity; massFlowRate constant -0.003833; //-0.004167 value uniform (0 0 0); } SYM_1_OBEN { type cyclicAMI; } SYM_1_UNTEN { type cyclicAMI; } SYM_2_OBEN { type cyclicAMI; } SYM_2_UNTEN { type cyclicAMI; } MOVINGWALL_OBEN { type rotatingWallVelocity; origin (0 0 0); axis (1 0 0); omega 838; } MOVINGWALL_UNTEN { type rotatingWallVelocity; origin (0 0 0); axis (1 0 0); omega 838; } BOHRUNG { type fixedValue; value uniform (0 0 0); } WALL_OBEN { type fixedValue; value uniform (0 0 0); } WALL_UNTEN { type fixedValue; value uniform (0 0 0); } PLENUMWALL { type fixedValue; value uniform (0 0 0); } KEIL { type fixedValue; value uniform (0 0 0); } GAP_S { type fixedValue; value uniform (0 0 0); } GAB_W { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default cellLimited Gauss linear 1.0; } divSchemes { default bounded Gauss upwind; div(phi,U) bounded Gauss upwind;//bounded Gauss upwind; div((muEff*dev2(T(grad(U))))) Gauss linear; div(phi,e) bounded Gauss upwind; div(phi,k) bounded Gauss linear; div(phi,omega) bounded Gauss linear; div(phi,Ekp) bounded Gauss upwind; } laplacianSchemes { default Gauss linear limited 0.5; //Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.5; //corrected } fluxRequired { default no; p ; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-08; relTol 0.05; smoother GaussSeidel; cacheAgglomeration off; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.1; } e { solver PBiCG; preconditioner DILU; tolerance 1e-15; //1e-09 relTol 0.1; } "(k|omega)" { $U; tolerance 1e-09; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 2; rhoMin rhoMin [ 1 -3 0 0 0 ] 1.5; rhoMax rhoMax [ 1 -3 0 0 0 ] 5; // transonic true; residualControl { p 1e-6; U 1e-6; e 1e-6; // possibly check turbulence fields "(k|epsilon|omega)" 1e-9; } } relaxationFactors { fields { p 0.3; //0.1 rho 0.05; //0.05 } equations { U 0.7; //0.7 k 0.7; //0.7 omega 0.7; //0.7 e 0.3; //0.7 } } potentialFlow { nNonOrthogonalCorrectors 10; } // ************************************************************************* // Could it be, that the "flowrateInletVelocity" causes those problems? I considered using a pressure condition for the outlet as well, but the problem with this approach is, that the fluid at the outlet has a very high rotational velocity so that there is a large pressure variation over the diameter. Last edited by Werne; February 11, 2015 at 09:05. |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
