InternalMesh as wall
Old   February 12, 2015, 08:56
Default InternalMesh as wall
Kalyan Peri
kalyan is on a distinguished road
Hello everyone,
i want to simulate flow over perforated plate which is inside a cylinder. using topoSet i have created a cellSet for perforated plate. Now how can i define this cellSet as wall? the perforated plate is 2mm thick. i tried using createBaffles but there was some error from solver.. any help is greatly appreciated. Thankyou
kalyan is offline   Reply With Quote
Old   February 12, 2015, 09:52
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
As it is just "flow" I assume that it is incompressible flow and you are using pimpleFoam solver. You can use explicitPorositySource fvOption with very high Darcy (d) coefficient (you can set Forchheimer coefficient to 0) for your cellSet.
alexeym is offline   Reply With Quote
Old   February 12, 2015, 10:03
Kalyan Peri
Thank you for the reply. I think the solution you said should work.
Regards,
Kalyan
Old   February 16, 2015, 06:09
Kalyan Peri
Hi alexey,
I have few doubts. what happens if i give some value to f (forchheimer coefficient) for explicit porosity?
As mentioned in the first post, i have created a 2mm thickness Plate with holes(perforated plate) as cellZone. Now i used this cellZone as porous medium and defined values as d = 0 and f = 10^7. The results looks fine, like velocity of the air at the cellZone is 0 and flow is only though non cellZone(i.e holes).
my doubt is that is how to select the values of d and f(darcy and forchheimer coefficient for explicit porosity) such that the porous medium almost behaves like wall.
** a little correction, flow is not incompressible. i am using air as fluid, and solver is rhoPimpleFoam
Thank you
Regards,
kalyan
Old   February 16, 2015, 07:17
Alexey Matveichev
Well, it will be easier to go with d ~ 1e16 and f ~ 0. To estimate d you can use, for example, Kozeny-Carman (https://en.wikipedia.org/wiki/Kozeny–Carman_equation) equation. In your case as you would like medium to act like a solid, epsilon in the equation should be low.
internal wall, perforated plate
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 05:37
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
