bounded Gauss upwind Scheme
Like Tree2Likes
  • 2 Post By Tushar@cfd
Old   February 23, 2015, 05:35
Default bounded Gauss upwind Scheme
deepinheart is on a distinguished road
I run a case using simpleFoam in OF 230 and everything goes well. When I turn to OF ext 3.1, I can't find 'bouned Gauss upwind' scheme as before. Instead, I use 'Gauss upwind' but it failed.
Anybody has similar experience? Would you please explain which one is the similar to 'bounded Gauss upwind'?
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    // added for Of ext3.1
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    //div(phi,U)      bounded Gauss upwind;
    //div(phi,k)      bounded Gauss upwind;
    //dv(phi,epsilon) bounded Gauss upwind;
    //div(phi,R)      bounded Gauss upwind;
    //div(R)          Gauss linear;
    //div(phi,nuTilda) bounded Gauss upwind;
    //div((nuEff*dev(T(grad(U))))) Gauss linear;
    div(phi,U)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,R)      Gauss upwind;
    div(phi,nuTilda) Gauss upwind;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
    //default         Gauss linear corrected;
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
deepinheart is offline   Reply With Quote
Old   February 23, 2015, 05:57
T. Chourushi
Tushar@cfd is on a distinguished road
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
gradSchemes
divSchemes
    default         none;
laplacianSchemes
    default         none;
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
Dear Deepinheart,
I would you suggest you to have a look at the following post:
http://www.cfd-online.com/Forums/ope...end-3-1-a.html
As suggested by H. Jasak use:
Gauss upwind Gauss linear
This will work
Best Luck!
Ramzy1990 and openfoam_aero like this.
Tushar@cfd is offline   Reply With Quote
Free Surface Ship Flow timfranke OpenFOAM Running, Solving & CFD 322 March 3, 2021 09:04
Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPO adarsh tiwari OpenFOAM Running, Solving & CFD 9 May 17, 2018 06:59
Implementation of 2nd order upwind scheme jaason OpenFOAM Running, Solving & CFD 4 February 6, 2015 17:40
bounded Gauss and normal Gauss question Tobi OpenFOAM 2 June 18, 2013 00:35
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
