cyclicAMI get separated after floating
Old   March 12, 2015, 06:03
Default cyclicAMI get separated after floating
chun is on a distinguished road
Dear all,
I am trying to combine the floatingObject ase and the propeller case in tutorials. I am using the version 2.3.0.
In the dynamicMeshDict, I put the cyclicAMI goes with the turbine. Hope they will floating together. I still have other part there to support the turbine, but let we just ignore that part and focus on the cyclicAMI part.
solver              sixDoFRigidBodyMotion;
sixDoFRigidBodyMotionCoeffs
    patches         (cyclicAMI turbine);
    innerDistance   0.05;
    outerDistance   0.35;
        mass            9.35368739253;
        centreOfMass    (0.499999998734 0.499643542159 0.406767085799);
        momentOfInertia (0.189180500074 0.189186953613 0.271681686205);
        orientation     (0.999999999989 -4.77090807147e-06 4.87915467083e-08
                         4.77033850929e-06 0.999965469686 0.00831019932107
                        -8.8437064246e-08 -0.0083101993204 0.999965469697);
    report          on;
    accelerationRelaxation 0.7;
However, after 0.03 second, the cyclicAMI get separated like the photo that I attached. You can also see the animation at https://www.dropbox.com/s/zliiynsein...side_whole.gif
Is anyone knows how I can floating them together?
Thanks
chun is offline   Reply With Quote
Old   March 19, 2015, 09:11
I will just answer myself.
Since I build my own motion function and I will move the axis, origin also the CyclicAMI mesh during the process, I move them in the wrong position. Hence, the AMI spin around the wrong axis will cause the separated.
Floating Point Exception Error nyox FLUENT 11 November 30, 2018 12:31
Boundary Layer strange result fernexda OpenFOAM Running, Solving & CFD 14 January 15, 2015 07:21
problem with cyclicAMI and wall distance Maff OpenFOAM Bugs 5 August 14, 2014 14:41
CyclicAMI Boundary Condition CUBoulderPhDStudent OpenFOAM Running, Solving & CFD 0 May 21, 2014 18:34
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 03:44
