What farfield settings for komegaSST with o-mesh?
Old   March 23, 2015, 05:23
Default What farfield settings for komegaSST with o-mesh?
Klaus
klausb will become famous soon enough
I've changed the mesh and AOA setting approach of a case and can't reproduce the results.
Changes:
1: The mesh was changed from a rectangular mesh created with snappyHexMesh and a tool which helped to get the y+ = 1 right to an o-mesh with y+ = 1.
- the rectangular mesh had the following boundary patches: inlet, outlet, top, bottom, front, back, airfoil
- the o-mesh has front, back, airfoil, farfield
2: The AOA (6.24°) was initially set in the mesh, it's now set by setting the x,z components of the velocity in the U (14.6 m/s) file. The mesh was/is in the x,z plane. The directions in the forceCoeffs file to calculate x,z were adjusted accordingly.
Results:
Expected: cl = 1.14 cd = 0.0225
Current result: cl = 1.6 cd = -0.025 (negative!)
Strange U/p results visible in paraFoam (see attachment farfield_error)
U file:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (14.513 0 1.587); // angle of attack = 6,24° vx=v*cos(6,24°), vy=v*sin(6,24°)
boundaryField
front
type empty;
back
type empty;
airfoil
type fixedValue;
value uniform (0 0 0);
farfield
type freestream;
freestreamValue uniform (14.513 0 1.587);
forceCoeffs file:
forces
type forces;
functionObjectLibs ("libforces.so");
outputControl timeStep;
outputInterval 1;
patches ("airfoil");
pName p;
UName U;
rhoName rhoInf;
log true;
CofR (0.25 0 0);
rhoInf 1.225;
forceCoeffs
type forceCoeffs;
outputInterval 1;
pName p;
UName U;
rhoName rhoInf;
log true;
liftDir (-0.108653 0 0.994075);
dragDir (0.994075 0 0.108653);
CofR (0.25 0 0);
pitchAxis (0 1 0);
magUInf 14.6;
rhoInf 1.225;
lRef 1;
Aref 0.1;
boundary file:
4
front //auto1
type empty;
nFaces 40800;
startFace 81300;
back //auto2
type empty;
nFaces 40800;
startFace 122100;
airfoil //auto3
type wall;
nFaces 300;
startFace 162900;
farfield //auto4
type patch;
nFaces 300;
startFace 163200;
What's wrong with the farfield settings?
What's wrong with the AOA settings?
Klaus
File Type: gz 0.org.tar.gz (832 Bytes, 0 views)
klausb is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 19:54
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
