March 18, 2015, 09:49 |
OpenFOAM - No change in Alpha, condensation
ARUN
Rep Power: 11 |
Hi Foamers,
I am trying to estimate heat transfer over vertical surfaces using twoPhaseEulerFoam. I have got the variation of thermal n velocity profile as required bt the problem is there isnt any variation for alpha as the process is condensation. I tried to make several changes in equation sets and formulations bt nthng is seems to be working... any suggestions? |
June 5, 2015, 07:15 |
#2 | |
Rep Power: 15 |
Did you manage to sort it out? I think, you should put some small number for alpha1 because condensation depends on alpha1, if you check the code, you can see it... what is the geometry are you using? and p_rgh BC? Quote:
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 12:44 |
Setting up heat transfer beetween wall heated zone and flow channel zone in Fluent | tafa | Fluent Multiphase | 0 | May 25, 2014 05:08 |
Conjugate heat transfer in reacting flow | ali_1364reza | OpenFOAM | 1 | May 30, 2012 14:15 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 15:35 |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 04:53 |
