A strange behaviour in oneEqEddy sub-grid scale in LES of a reacting flow
Old   April 12, 2015, 10:30
Default A strange behaviour in oneEqEddy sub-grid scale in LES of a reacting flow
Bobby
babakflame is on a distinguished road
Dear Foamers
I am trying to simulate a bluff-body stabilized non-premixed flame. Previously, I have simulated this case with Smagorinsky and spallart-Allmaras sub-grid scales with no problem. I have taken Courant number in these simulations 0.36 and the case was successfully simulated.
Nevertheless, during my simulation with oneEqEddy sub-grid scale a strange behavior happens. After the flow reaches the outlet of the domain, an oscillation occurs in the courant number. I mean the courant number increases partially and the the time step collapses from around 1e-07 to 1e-014. Even, I have examined Courant numbers as low as 0.18 and this phenomenon happens again. I think 0.18 is a relatively low value for Courant number.
All files including the LESProperties and U and P are the same for three utilized sub-grid scales i.e. Smagorinsky, Spallart-Allmaras and oneEqEddy models. Nonetheless, this significant collapse of time step happens only in oneEqeddy sub-grid scale.
Here are the LESProperties, U and P files repectively. My case contains a Cylindrical grid which features a bluff-body seperating fuel and oxidizer streams.
 LESModel        oneEqEddy;
printCoeffs     on;
delta        vanDriest;
vanDriestCoeffs
    delta           cubeRootVol;
    cubeRootVolCoeffs
        deltaCoeff      1;
    smoothCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        maxDeltaRatio   1.1;
    Aplus           26;
    Cdelta          0.158;
 FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0.995722";
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101325;
boundaryField
    OUTLET
        type            waveTransmissive;
        gamma           1.4;
        fieldInf        101325;
        lInf            0.025;
        value           uniform 101325;
    COFLOW
        type            zeroGradient;
    SIDE
        type            fixedValue;
    FUEL
        type            zeroGradient;
    WALL
        type            zeroGradient;
 FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0.1 0);
boundaryField
    OUTLET
        type            zeroGradient;
    COFLOW
        type            fixedValue;
        value           uniform (0 40 0);
    SIDE
        type            zeroGradient;
    FUEL
        type            turbulentInlet;
        referenceField  nonuniform List<vector>
252
(-0.296506256 142.798641 0.146544894)
(-0.334651696 142.991259 -0.0378759468)
 (-1.8824955152    4.9390407   0.144344149)
(0.4145645725     -1.4054917  -0.694103849)
    WALL
        type            fixedValue;
        value           uniform (0 0 0);
Any hint is appreciated.
Best
Bobi
babakflame is offline   Reply With Quote
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
Grid size in LES Jin Li Main CFD Forum 1 May 19, 2000 10:02
ratio grid resolution (near wall/center) of dispersed bubbly flow columns using LES Ridwan Setiadi Arrizar Main CFD Forum 1 January 30, 1999 17:43
