A strange behaviour in oneEqEddy sub-grid scale in LES of a reacting flow |
April 12, 2015, 10:30 |
Bobby
Dear Foamers
I am trying to simulate a bluff-body stabilized non-premixed flame. Previously, I have simulated this case with Smagorinsky and spallart-Allmaras sub-grid scales with no problem. I have taken Courant number in these simulations 0.36 and the case was successfully simulated. Nevertheless, during my simulation with oneEqEddy sub-grid scale a strange behavior happens. After the flow reaches the outlet of the domain, an oscillation occurs in the courant number. I mean the courant number increases partially and the the time step collapses from around 1e-07 to 1e-014. Even, I have examined Courant numbers as low as 0.18 and this phenomenon happens again. I think 0.18 is a relatively low value for Courant number. All files including the LESProperties and U and P are the same for three utilized sub-grid scales i.e. Smagorinsky, Spallart-Allmaras and oneEqEddy models. Nonetheless, this significant collapse of time step happens only in oneEqeddy sub-grid scale. Here are the LESProperties, U and P files repectively. My case contains a Cylindrical grid which features a bluff-body seperating fuel and oxidizer streams. Code:
LESModel oneEqEddy; printCoeffs on; delta vanDriest; vanDriestCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Aplus 26; Cdelta 0.158; } Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0.995722"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { OUTLET { type waveTransmissive; gamma 1.4; fieldInf 101325; lInf 0.025; value uniform 101325; } COFLOW { type zeroGradient; } SIDE { type fixedValue; value uniform 101325; } FUEL { type zeroGradient; } WALL { type zeroGradient; } } // Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "0.995722"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0.1 0); boundaryField { OUTLET { type zeroGradient; } COFLOW { type fixedValue; value uniform (0 40 0); } SIDE { type zeroGradient; } FUEL { type turbulentInlet; referenceField nonuniform List<vector> 252 ( (-0.296506256 142.798641 0.146544894) (-0.334651696 142.991259 -0.0378759468) ... ... ... (-1.8824955152 4.9390407 0.144344149) (0.4145645725 -1.4054917 -0.694103849) ); } WALL { type fixedValue; value uniform (0 0 0); } } Best Bobi |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
Grid size in LES | Jin Li | Main CFD Forum | 1 | May 19, 2000 10:02 |
ratio grid resolution (near wall/center) of dispersed bubbly flow columns using LES | Ridwan Setiadi Arrizar | Main CFD Forum | 1 | January 30, 1999 17:43 |
