April 27, 2015, 05:46 |
keyword writeFrequency is undefined
Dear Foamers,
for testing purposes I've restarted an LES case on a shared memory system. The first run could smoothly be started. With the optimal hierarchical decomposition strategy the simulation time that could be reached on the shared memory system was higher then the simulation time reached on a distributed memory system (dual socket octo Core AMD Magny Cours). Hence a restart of the LES on the shared memory system, which might be necessary for higher simulation times, gives this error: Code:
--> FOAM FATAL IO ERROR: [19] keyword writeFrequency is undefined in dictionary "/home/hpc/.../OpenFOAM/user-2.3.1/run/LES_test/processor119/system/controlDict" [19] [19] file: /home/hpc/.../OpenFOAM/user/run/LES_test/processor119/system/controlDict from line 0 to line 0. [19] [19] From function dictionary::lookupEntry(const word&, bool, bool) const [19] in file db/dictionary/dictionary.C at line 437. [19] FOAM parallel run exiting [19] application called MPI_Abort(MPI_COMM_WORLD, 1) - process 119 Ayla |
February 28, 2018, 08:05 |
I had the same error message.
On my side it was because of a ';' missing at the end of one line (after the writeControl keyword) |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
