June 4, 2015, 18:25 |
Running parallel hangs
Piotr Kuna
Rep Power: 10 |
Hi.
I have used openfoam a few days. Got some tutorials to run on my ubuntu workstation. I managed to run the solver on 4 cores on my workstation. Now i am trying to run over the network on two workstations. The second is ubuntu too. Installed the same version (2.4.0). All path are identical. Some testcases solved on the second workstation so it's working fine. I interchanged the ssh keys so i can connect between both workstations freely without passwords. Username is the same. As i try to run the solver via mpirun or foamJob it's starting, but seems to hand at the beginning. The processes on the both workstations are starting, cpu load goes as expected. But the output freeze here: Code:
piotr@biuro-4:~/OpenFOAM/piotr-2.4.0/run/tutorials/multiphase/compressibleInterFoam/laminar/depthCharge3D$ foamJob -s -p compressibleInterFoam Parallel processing using SYSTEMOPENMPI with 2 processors Executing: /usr/bin/mpirun -np 2 -hostfile machines -x FOAM_SETTINGS /opt/openfoam240/bin/foamExec -prefix /opt compressibleInterFoam -parallel | tee log /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : compressibleInterFoam -parallel Date : Jun 05 2015 Time : 00:12:50 Host : "biuro-4" PID : 22797 ^Cmpirun: killing job... I go down to two cores, one on each machine, no difference. I have mounted the ~/OpenFOAM/piotr-2.4.0/run directory via nfs share to the second workstatoon on the same path. Running ls -l via mpi gives expected result. Code:
piotr@biuro-4:~/OpenFOAM/piotr-2.4.0/run/tutorials/multiphase/compressibleInterFoam/laminar/depthCharge3D$ mpirun --hostfile machines -np 2 ls -l total 4512 drwxr-xr-x 2 piotr piotr 4096 Jun 4 00:38 0 -rwxr-xr-x 1 piotr piotr 240 May 30 15:57 Allclean -rwxr-xr-x 1 piotr piotr 492 May 30 15:57 Allrun -rw-rw-r-- 1 piotr piotr 2377766 Jun 4 11:28 bubble.ogv drwxr-xr-x 3 piotr piotr 4096 May 30 15:57 constant -rw-rw-r-- 1 piotr piotr 2190057 Jun 4 10:46 depthCharge3D.ogv -rw-rw-r-- 1 piotr piotr 0 Jun 4 10:08 foam.foam -rwxrwxr-x 1 piotr piotr 55 Jun 4 00:22 go -rw-rw-r-- 1 piotr piotr 702 Jun 5 00:12 log -rw-rw-r-- 1 piotr piotr 702 Jun 4 23:00 log.txt -rw-rw-r-- 1 piotr piotr 16 Jun 5 00:08 machines drwxrwxr-x 4 piotr piotr 4096 Jun 5 00:08 processor0 drwxrwxr-x 4 piotr piotr 4096 Jun 5 00:08 processor1 drwxr-xr-x 2 piotr piotr 4096 May 30 15:57 system total 4512 drwxr-xr-x 2 piotr piotr 4096 Jun 4 00:38 0 -rwxr-xr-x 1 piotr piotr 240 May 30 15:57 Allclean -rwxr-xr-x 1 piotr piotr 492 May 30 15:57 Allrun -rw-rw-r-- 1 piotr piotr 2377766 Jun 4 11:28 bubble.ogv drwxr-xr-x 3 piotr piotr 4096 May 30 15:57 constant -rw-rw-r-- 1 piotr piotr 2190057 Jun 4 10:46 depthCharge3D.ogv -rw-rw-r-- 1 piotr piotr 0 Jun 4 10:08 foam.foam -rwxrwxr-x 1 piotr piotr 55 Jun 4 00:22 go -rw-rw-r-- 1 piotr piotr 702 Jun 5 00:12 log -rw-rw-r-- 1 piotr piotr 702 Jun 4 23:00 log.txt -rw-rw-r-- 1 piotr piotr 16 Jun 5 00:08 machines drwxrwxr-x 4 piotr piotr 4096 Jun 5 00:08 processor0 drwxrwxr-x 4 piotr piotr 4096 Jun 5 00:08 processor1 drwxr-xr-x 2 piotr piotr 4096 May 30 15:57 system Can you help me? What have i missed? |
June 6, 2015, 04:48 |
Piotr Kuna
Rep Power: 10 |
OK, solved this problem by self. I had multiple IP adresses on the first workstation. It was a communication issue. As i removed the other subnets from my network interface it started to work now :-)
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 21:33 |
Running mapFields with Parallel Source and Parallel Target | RDanks | OpenFOAM Pre-Processing | 4 | August 2, 2016 05:24 |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 08:53 |
error when running in parallel, but succeed in a single core. | sharonyue | OpenFOAM Running, Solving & CFD | 1 | December 12, 2014 13:24 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 03:50 |
