October 27, 2010, 08:04 |
Euler, Backward time schemes
Claus Meister
Rep Power: 17 |
Dear Foamers,
hopefully someone has already experience with the Versteeg book and the Euler and backward time scheme. In Versteeg, three schemes are discussed from which I don't know which belongs to Euler and which to backward. Can anybody help? Cheers in advance |
October 27, 2010, 14:06 |
Santiago Marquez Damian
Rep Power: 23 |
If I interpreted well, Versteeg discusses three temporal schemes: explicit, fully implicit and Crank Nicholson, where fully implicit stands for Backward Euler and explicit for Forward Euler. Explicit scheme ins't implemented in FOAM as an option for Time Schemes, Crank Nicholson is the same (but you can tune up a parameter), Backward Euler is Euler in FOAM. Finally Backward from FOAM is not explained in Versteeg I think, and basically is a second order time scheme, using previous, actual and next time step data.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
October 27, 2010, 17:48 |
Claus Meister
Rep Power: 17 |
Let me change my question: is backward just the backward differencing formula approach (BDF) ?
October 27, 2010, 18:09 |
Rep Power: 23 |
Backward Scheme formulation is explained in Programmer's guide as a second order scheme in stead of backward differencing, that, at least as I know it, is a first order differencing scheme.
Regards.
December 17, 2015, 09:16 |
#5 | |
SINA.KHAYYAM
Rep Power: 10 |
I want to implement the Forward Euler scheme in open Foam. In order to write it i need to get help from its Backward scheme. Unfortunately i cannot find it in Open Foam. I would like to know if you can show me the suitable path in Open Foam to get it and compare it with the Forward scheme which i wrote. Cheers in advance |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Implicit versus Explicit | Deepak | Main CFD Forum | 17 | November 7, 2015 13:14 |
problem with second order backward Euler scheme | shahpar73 | CFX | 1 | September 28, 2010 18:54 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
