Adding an acceleration source term to interFoam
Like Tree2Likes
  • 1 Post By olivierG
Old   July 10, 2015, 08:19
Default Adding an acceleration source term to interFoam
Arsalan
arsalan.dryi is on a distinguished road
Dear Foamers,
I want to study the shape oscillation an translation motion of a single bubble in a liquid container under vibration while the imposed displacement of the container is y=Acos(wt).
for this purpose,i should add an acceleration source term to momentum equation.
I'm trying to modify the interFoam equations by adding a source term to the momentum equation,
UEqn.H :
 dimensionedVector accY
          "accY",dimensionSet(0, 1, -2, 0, 0),vector(0, 1, 0)
        scalar Pi = 3.14;
       dimensionedVector acc = (-396270.25*0.0002*Foam::cos(629.5*runTime.value())*accY);
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(rhoPhi, U)
      + turbulence->divDevRhoReff(rho, U)
        (acc*rho)
    UEqn.relax();
    if (pimple.momentumPredictor())
        solve
            UEqn
            fvc::reconstruct
                    fvc::interpolate(interface.sigmaK())*fvc::snGrad(alpha1)
                  - ghf*fvc::snGrad(rho)
                  - fvc::snGrad(p_rgh)
                ) * mesh.magSf()
but this method get wrong results,What's wrong with it??
I would appreciate your comments!
Thanks a lot,
Arsalan.
File Type: h UEqn.H (816 Bytes, 15 views)
arsalan.dryi is offline   Reply With Quote
Old   July 10, 2015, 10:32
Olivier
olivierG is on a distinguished road
hello,
Take a look at how gravity source term is take into account.
And do the same.
regards,
olivier
arsalan.dryi likes this.
olivierG is offline   Reply With Quote
Old   July 10, 2015, 13:16
Arsalan
Well, with the extra help of Olivier I got the following to compile:
UEeqn.H :
        scalar Pi = 3.14;
       dimensionedVector acc = (-396270.25*0.0001*Foam::cos(629.5*runTime.value())*accY);
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
    UEqn.relax();
        solve
            UEqn
            fvc::reconstruct
                  + acc*fvc::snGrad(rho)
                ) * mesh.magSf()
but i got this error when i want to compile the code :
 UEqn.H:35:40:   instantiated from here
/opt/openfoam221/src/OpenFOAM/lnInclude/FieldFunctions.C:700:1: error: no match for ‘operator+’ in ‘*(f2P ++) + *(f3P ++)
i just add the
to momentum equation!
Every help, idea, hint... will be greatly apprecitated!
Thanks a lot,
Arsalan.
Old   July 10, 2015, 13:56
Olivier
hello,
Try to follow more closely what's done with g:
acc = ...; //ok
gh = (acc+g) &mesh.C();
ghf = (acc+g) & mesh.Cf();
.. then you don't have to add acc in momentum predictor.
regards,
Olivier
Old   July 10, 2015, 18:00
Arsalan
Dear Olivier,
thank u for your reply,but how do i modify the gh and ghf(and at which file)?
Best regards,
Arsalan
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Adding volumetric Source Term mohanamuraly OpenFOAM 0 May 17, 2009 23:00
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
