Buoyancy driven incompressible Flow
Like Tree1Likes
  • 1 Post By pbachant
Old   July 17, 2015, 16:29
Default Buoyancy driven incompressible Flow
iafpython's Avatar
Igor
iafpython is on a distinguished road
Dear Foamers:
I would like an advice of yours for running a simulation of an incompressible fluid, in an enclosed structure; with a heat source, the fluid transfers heat from the source to the walls.
I would like to use the HotRoom case but I cant find a description of it (type of solver, BC's ,etc, etc), also I would like to see cases where some of the appropiated solvers (of the standard solvers ; buoyantBoussinesqSimpleFoam) were ran,
Best Regars,
Igor
iafpython is offline   Reply With Quote
Old   July 17, 2015, 21:29
Pete Bachant
pbachant is on a distinguished road
You can take a look in the hotRoom tutorials case directory to infer what's going on. The solver is buoyantBoussinesqSimpleFoam. If you look in the "0" directory you will see all the initial-boundary conditions for the flow variables. In constant/polyMesh/blockMeshDict you will see how the mesh is generated and how the patches are named. In system/controlDict you will see the solver parameters. In system/setFieldsDict you will see how the initial temperature field is set. The "Allrun" script will run the whole simulation for you--creating the mesh, setting the initial temperature, then running the solver.
iafpython likes this.
Home | Twitter | GitHub
pbachant is offline   Reply With Quote
fan driven flow, Fan BC validation (getting lost) soonic OpenFOAM Running, Solving & CFD 0 July 7, 2013 19:16
Boudaries for bouynat driven flow with additional mass flux at inlet Charon CFX 2 April 27, 2013 08:02
3D Buoyancy driven flow in annulus Aditya Main CFD Forum 0 February 20, 2007 01:21
bitumen buoyancy driven flow Diego Peinado FLUENT 1 August 9, 2005 14:42
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
