April 20, 2015, 15:22 |
SimpleFoam crash at first loop
alvaro
Rep Power: 11 |
Hi people,
I'm new user in OF and I appreciate any reply. I'm trying to solve a simple case with high pressure at inlet and low pressure at outlet. And the velocity is unknown in both cases (one of the purposes is to determinate the velocity at output). First I did was check the mesh, and I think this is ok. Code:
Create polyMesh for time = 0 Time = 0 Mesh stats points: 352020 faces: 1020530 internal faces: 985870 cells: 334400 faces per cell: 6 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 334400 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology fixedwall 11160 11531 ok (non-closed singly connected) inlet 3200 3321 ok (non-closed singly connected) outlet 1600 1671 ok (non-closed singly connected) sym 18700 19060 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-1.5 -5.55112e-17 -0.7) (0 1.5 1.95) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.45026e-14 1.20956e-14 3.91972e-16) OK. Max cell openness = 4.0813e-16 OK. Max aspect ratio = 19.5931 OK. Minimum face area = 1.1577e-05. Maximum face area = 0.00177197. Face area magnitudes OK. Min volume = 2.02597e-07. Max volume = 3.10095e-05. Total volume = 1.752. Cell volumes OK. Mesh non-orthogonality Max: 42.9364 average: 6.59459 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.19711 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } No finite volume options present SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Starting time loop Time = 1 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #5 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #6 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #7 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" Floating point exception (core dumped) U Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { fixedwall { type zeroGradient; } inlet { type fixedValue; value uniform (0 0 0); } outlet { type fixedValue; value uniform (0 0 0); } sym { type symmetry; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 100000; boundaryField { fixedwall { type zeroGradient; } inlet { type fixedValue; value uniform 100000; } outlet { type fixedValue; value uniform 0; } sym { type symmetry; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.375; boundaryField { fixedwall { type kqRWallFunction; value uniform 0; } inlet { type fixedValue; value uniform 0.375; } outlet { type fixedValue; value uniform 14.855; } sym { type symmetry; } } Code:
dimensions [0 2 -3 0 0 0 0]; internalField uniform 14.855; boundaryField { fixedwall { type epsilonWallFunction; value uniform 14.855; } inlet { type fixedValue; value uniform 14.855; } outlet { type fixedValue; value uniform 14.855; } sym { type symmetry; } } Code:
dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { fixedwall { type nutkWallFunction; value uniform 0; } inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } sym { type symmetry; } } Code:
transportModel Newtonian; nu nu [ 0 2 -1 0 0 0 0 ] 1e-05; CrossPowerLawCoeffs { nu0 nu0 [ 0 2 -1 0 0 0 0 ] 1e-06; nuInf nuInf [ 0 2 -1 0 0 0 0 ] 1e-06; m m [ 0 0 1 0 0 0 0 ] 1; n n [ 0 0 0 0 0 0 0 ] 1; } BirdCarreauCoeffs { nu0 nu0 [ 0 2 -1 0 0 0 0 ] 1e-06; nuInf nuInf [ 0 2 -1 0 0 0 0 ] 1e-06; k k [ 0 0 1 0 0 0 0 ] 0; n n [ 0 0 0 0 0 0 0 ] 1; } Code:
RASModel kEpsilon; turbulence on; printCoeffs on; Code:
application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 500; deltaT 1; writeControl timeStep; writeInterval 10; purgeWrite 5; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,R) bounded Gauss upwind; div(R) Gauss linear; div(phi,nuTilda) bounded Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 0.222; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default limited 0.222; } fluxRequired { default no; p ; } Code:
solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } "(U|k|epsilon|R|nuTilda)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 0; residualControl { p 1e-2; U 1e-3; "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; epsilon 0.7; R 0.7; nuTilda 0.7; } } Regards. |
April 21, 2015, 01:25 |
Vojtech Betak
Rep Power: 18 |
I have seen there an error, that is connected with the wrong definition of boundary conditions. Usually on inlet (in the case of U, k, epsilon) you are defining fixed value and on outlet zeroGradient or inletOutlet should be specified. For pressure you have to presribed on inlet zeroGradient and on outlet fixedValue.You can used also totalPressure for p and pressureDirectedInlet for Uin the case of inlet BC
Please check some tutorials and compared it with your case. |
April 27, 2015, 04:33 |
#3 | |
alvaro
Rep Power: 11 |
Thanks for reply. I tried all you suggested. After to read many post I think the best option for my Bc's are: Totalpressure (inlet) and fixedValue (outlet) pressureInletOutletVelocity (inlet) and inletOutlet (outlet) What do you think? But my problem still appear... I tried to change the Numerical Schemes to 1st Order, I tried to change the Turbulence Model (Laminar, k-e...) even tried with solver pisoFoam and the same Bc's. I checked pitzDaily tutorial because is similar to my problem. I caught case folders and changed the geometry and the respective patchfields but neither worked. Always cashed in the first loop: Code:
Time = 1 smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 1 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #8 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" /home/alvaro/OpenFOAM/Engys/N2D_pisoFoam/solver_serial.run: line 30: 4371 Floating point exception(core dumped) $SOLVER -case $CASE 2>&1 4372 Done | tee $LOG What more could I do? Cheers. |
April 27, 2015, 05:48 |
Vojtech Betak
Rep Power: 18 |
I think there is still an error in your BC. Can you post it?
April 27, 2015, 14:14 |
alvaro
Rep Power: 11 |
Hi Vojtech,
p Code:
dimensions [ 0 2 -2 0 0 0 0 ]; internalField uniform 1000.0; boundaryField { back { type empty; } front { type empty; } inlet { type totalPressure; p0 uniform 1000; value uniform 1000; rho none; psi none; U U; phi phi; gamma 1; } outlet { type fixedValue; value uniform 100; } sym { type symmetryPlane; } wall1 { type zeroGradient; } wall2 { type zeroGradient; } } Code:
dimensions [ 0 1 -1 0 0 0 0 ]; internalField uniform (0.0 0.0 0.0); boundaryField { back { type empty; } front { type empty; } inlet { type pressureInletOutletVelocity; value uniform ( 0 0 0); } outlet { type inletOutlet; value uniform (0 0 0); inletValue uniform (0 0 0); } sym { type symmetryPlane; } wall1 { type fixedValue; value uniform ( 0 0 0); } wall2 { type fixedValue; value uniform ( 0 0 0); } } Code:
Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.314744, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.285886, No Iterations 1000 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #8 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" Floating point exception (core dumped) Thanks |
August 17, 2015, 07:17 |
simpleFoam crashes in first loop
Surya Kiran
hello alvaro,
I am having similar problem as you and my boundary conditions seems ok. Were you able to find out the problem? //surya |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
simpleFoam crushes at 1st Time loop. | seav | OpenFOAM Running, Solving & CFD | 18 | June 4, 2013 08:18 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
