Running parallel case after parallel meshing with snappyHexMesh? |
August 31, 2015, 22:04 |
Rep Power: 12 |
I am working on simulating steady state resistance for ship hydrodynamics, using LTSInterFoam, and meshing with snappyHexMesh. In order to speed up the meshing process and use resources to capacity, I am meshing in parallel, which works fine, until I try to run. My exact process is:
When I try to run the solver, it fails with a multitude of errors, complaining that it cant find faces, that mesh sizes are not the same etc. However, I tried to run reconstructParMesh, followed by again decomposing mesh, which worked, but led to me loosing the boundary layer refinement. Have any of you succeeded in running a parallel solver directly after parallel meshing with snappyHexMesh? Do you have any ideas of what might be causing this? EDIT: I figured it out. I just needed to run "patchSummary" to set the boundary conditions on the mesh after snapping and layer insertion! Best regards, Adam Last edited by Adam Persson; August 31, 2015 at 23:55. Reason: Solved problem... |
Problem in Running OpenFoam in Parallel | himanshu28 | OpenFOAM Running, Solving & CFD | 1 | July 11, 2013 09:19 |
Running potentialFoam case with Gambit meshing | shuoxue | OpenFOAM Running, Solving & CFD | 0 | June 14, 2013 00:58 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
Running dieselFoam in parallel. | Palminchi | OpenFOAM | 0 | February 17, 2010 04:00 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
