August 31, 2015, 20:53 |
Stubborn epsilonm residual
Albert Yiamakis
Rep Power: 10 |
I am running RANS simulations using twoPhaseEulerFoam. While all other residuals decrease with time, that is not the case for epsilonm, which tends to stay constant. This is typical: I noticed that the fluidisedBed tutorial exhibits the same behavior. Is this expected then? Any clues as to why this is happening would be appreciated.
Home |
November 13, 2015, 11:25 |
Joachim Herb
Rep Power: 21 |
Hello Albert,
did you find a solution for your problem? I see exactly the same behavior. It can also be reproduced by changing the water velocity to something > 0 in the twoPhaseEulerFoam bubbleColumn tutorial. Thank you Joachim |
November 17, 2015, 11:42 |
Joachim Herb
Rep Power: 21 |
November 19, 2015, 06:20 |
Joachim Herb
Rep Power: 21 |
I filed a bug at the "official" bug tracker of OpenFAOM: http://www.openfoam.org/mantisbt/view.php?id=1916
It looks like it's also not clear to them what causes this problem. |
November 22, 2015, 08:08 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
I haven't checked the values and calculations, but here's what I know on this topic:
Best regards, Bruno
November 29, 2015, 14:15 |
Bruno Santos
Rep Power: 128 |
FYI: I was curious and took a look into this. See comment #5684: http://www.openfoam.org/mantisbt/view.php?id=1916#c5684
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
