Cd calculation when velocity is varying with time |
September 14, 2015, 04:25 |
DongHo
Rep Power: 12 |
Dear. Foamers
I am working on Cd calculation for the case of a changing velocity with the time using URANS with k-w SST (accelerated cylinder case). Actually, initial velocity 1 m/s and then, after 1 sec, 1 to 5 m/s, the velocity is linearly changing with a ramp profile until 2 sec, finally, 5 m/s will be kept until 6 sec. For this case, how I can set up the value of "magUInf" in a file "forceCoeffs" even though I set up the velocity profile in "U"? If the magnitude of velocity is not changing, "magUInf" is set to be initial velocity, though.. Please give me any advice if you have an experience like this. Thanks |
September 29, 2015, 19:36 |
Davi Barreira
Rep Power: 12 |
Indeed the coefficients are calculated using a fixed velocity. You can set up a fixed velocity in the forceCoeffs dictionary (like 1m/s) and then postprocess the results with a programming language (or Excel) by recalculating the force coefficientes based on the new velocity. So:
Cd = 2*D/(rho*U^2) If you put U = 1, then Cd' = 2*D/rho In your forceCoeffs.dat you have time, so you can use to calculate your velocity at a given time. U = f(t) Therefore, Cd = Cd'/(Ucalc^2) |
Elastic or Plastic Deformations in OpenFOAM | NickolasPl | OpenFOAM Pre-Processing | 36 | September 23, 2023 08:22 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Time varying velocity BC | tejasvikrishna | FLUENT | 3 | March 22, 2011 13:41 |
time varying inlet velocity | Zhe Liu | CFX | 0 | July 31, 2008 06:56 |
