using GMSH in OpenFoam
Old   September 9, 2015, 09:15
Default using GMSH in OpenFoam
Subhasree
Subhasree is on a distinguished road
Hi everyone,
I have used GMSH to mesh an external flow domain over a model building and using pisoFoam to simulate its flow. I am simulating laminar flow at sea-level conditions having velocity of 10 m/s.
I have converted the mesh from GMSh to OpenFoam, but on using pisoFoam solver I am getting the following error:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
Starting time loop
Time = 0.005
Courant Number mean: 0.166758 max: 7.5028
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4 Foam::GaussSeidelSmoother::smooth(Foam::Field<doub le>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 ? at ??:?
#7 ? at ??:?
#8 ? at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
Floating point exception (core dumped)
Please help me!!!
Subhasree is offline   Reply With Quote
Old   September 11, 2015, 02:48
Svensen is on a distinguished road
Courant number is too high. decrease deltaT in system/controlDict until the max Courant number will be less than 1.
Svensen is offline   Reply With Quote
Old   September 15, 2015, 08:00
Subhasree
Thank you for the reply. Problem solved!
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
[Gmsh] MVG with Gmsh for OpenFOAM fportela OpenFOAM Meshing & Mesh Conversion 2 March 26, 2013 03:57
[Technical] Salome + Gmsh or enGrid for OpenFOAM? wwrfd OpenFOAM Meshing & Mesh Conversion 2 July 21, 2011 10:38
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
[Gmsh] ANSYS GMSH OpenFOAM gtg627e OpenFOAM Meshing & Mesh Conversion 3 December 21, 2007 03:41
