September 25, 2015, 11:01 |
InterFoam - Error
Berat Loshi
Rep Power: 10 |
Hello People,
i´m trying to simulate with interFoam an turbulent flow in a Pool, after i make the Mesh with snappyHexMesh and after running the simulation i get this Error: 'in the Attachments' have anybody an Idea how to fix this Error? LG Berati |
September 25, 2015, 11:21 |
Rep Power: 10 |
i'm a newbie, but post 0/p_rgh and doublecheck if there's diskspace. looks like this happens after a few timesteps, or do you start at 0.003?
September 28, 2015, 08:05 |
Berat Loshi
Rep Power: 10 |
the Folder 0.003 is Created from SnappyHexMesh. Howerver i do. i Will get this Error!
October 1, 2015, 23:18 |
Dasein
Rep Power: 11 |
Hi Berati,
Seems that you are still having the folders from your SnappyHexMesh in your case folder. If that is the case, the solver might read them as time directories and ofc won't find any 0 folder inside. After you finished meshing with SHM, take the polyMesh folder from the last time (0.3) and copy paste it (after deleting the previous in there) on the constant folder. Then delete all your SHM created folders and run again. A nice way to have a clean folder and workflow is to rename the 0 folder into 0.org while meshing (especially if your decomposing this way you won't get errors). While running a simulation you can rename it back to 0. Hope this helps. Kind regards, Theodore. |
October 13, 2015, 07:37 |
Berat Loshi
Rep Power: 10 |
i thought the Problem is resolved, but now commes this Eroor, for that i realy dont found an explanation
Enyone know about this Problem : Gleitkomma -Ausnahme ? |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
