Problem with pimpleDyMFoam: Initialise steady state solution
Old   September 4, 2013, 11:11
Default Problem with pimpleDyMFoam: Initialise steady state solution
Lancester is on a distinguished road
Hello Foamer,
I succesful calculat a steady state solution of a radial fan. I used the simple-solver.
Now I like to calculate the same case with pimpleDyMFoam and so it is a transient case. I copy the last solution from simplesolver and paste it to my new pimple-case. I start my solution and it works. But when I start my solution I think only my Velocity-values are correctly read. Because My pressure Initial residuals are at the beginning at 0.99! My Ux, Uy, Uz resiudals are very low (0.00005)! Why???
Do someone knows the problem? If i calculate some timesteps and look at the solution, I can see a very good Velocity-field. My pressure field is so bad and the values increase.
Best Regards, Lancester
Lancester is offline   Reply With Quote
Old   September 6, 2013, 06:13
I tried a lot of things but I couldn't solve the problem. I used the propeller-tutorial as model. The only different is the using of 2 AMI-Interfacs. One at the Inlet of the fan and one a the outlet.
I take a transient solutien with pimpleDyMFoam with a very low Courant-number. After one timestep I look at the solution and my pressure-variables are very high (picture). But I initalize with unifom pressure of 0.
What could the reason for this? I tried a lot a boundary conditions but nothing works. My steadyState Solution works so I'm sure my mesh is good.
Thanks!
Old   September 29, 2015, 09:49
Sravan Kumar
coolcrasher is on a distinguished road
HI
Sorry for asking lately.
Any luck with the results ??
coolcrasher is offline   Reply With Quote
plz help,urgent, vof model steady state Garima Chaudhary FLUENT 4 March 15, 2018 12:22
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
steady state, laminar vof_model Garima Chaudhary FLUENT 0 May 24, 2007 03:11
Psedo-time steps in Steady state problem Blackdraft FLUENT 0 July 14, 2002 05:23
buoyancy driven flow in steady state in CFX4.3 raymondyin CFX 11 May 7, 2001 06:15
