how to avoid using wall function
Old   October 4, 2015, 09:09
Default how to avoid using wall function
Peter Hu
huecu588755 is on a distinguished road
Since I want to simulate the airfoil in a large stall angle,so I hope to use the low Re number turbulence model to resolve the sub layer.Then,how can I set to avoid using the wall function?
huecu588755 is offline   Reply With Quote
Old   October 6, 2015, 15:25
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
You do not want that FOAM set wall functions for your? In that case you should change the type of the boundary to patch.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   October 9, 2015, 05:03
Bazinga is on a distinguished road
Isn't it also possible to keep it as a wall and not use a wall function in the 0 time directory?
Bazinga is offline   Reply With Quote
Old   October 9, 2015, 13:59
Tobi's Avatar
Tobias Holzmann
Try it, if foam Set wall function also you set zeroGradient, change the type. I remember that sth. Like that was mentioned somewhere at openfoam.org site.
Keep foaming,
Tobias Holzmann
stall, wall function
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 11:55
How to implement wall function in my code? dli Main CFD Forum 5 May 21, 2015 03:57
Radiation interface hinca CFX 15 January 26, 2014 17:11
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
