October 4, 2015, 09:09 |
how to avoid using wall function
Peter Hu
Rep Power: 10 |
Since I want to simulate the airfoil in a large stall angle,so I hope to use the low Re number turbulence model to resolve the sub layer.Then,how can I set to avoid using the wall function?
October 6, 2015, 15:25 |
Tobias Holzmann
Rep Power: 51 |
You do not want that FOAM set wall functions for your? In that case you should change the type of the boundary to patch.
Keep foaming, Tobias Holzmann |
October 9, 2015, 05:03 |
October 9, 2015, 13:59 |
Tobias Holzmann
Rep Power: 51 |
Try it, if foam Set wall function also you set zeroGradient, change the type. I remember that sth. Like that was mentioned somewhere at openfoam.org site.
stall, wall function |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 11:55 |
How to implement wall function in my code? | dli | Main CFD Forum | 5 | May 21, 2015 03:57 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
