October 7, 2015, 16:48 |
Limiter in gamma scheme
Oliver Garbrecht
Hi everyone,
I wrote a little post-processing tool to evaluate in which areas of my domain the upwind scheme is used for interpolation when using the gamma scheme. The limiter / blending factor in the gamma scheme is calculated by Code:
min(max(phict/k_, 0), 1); However, I don't understand what happens if phict is larger than +1. The scheme should then be 100% upwind, as stated in the gamma-paper by Prof. Jasak. However, the limiter still is 1 instead of 0. What am I missing here? Many thanks in advance, Oliver |
gamma scheme, phict |
Flux Limiter and Interpolation Scheme | pablitobass | OpenFOAM Programming & Development | 10 | December 3, 2016 13:15 |
Why RNGkepsilon model gives floating error | shipman | OpenFOAM Running, Solving & CFD | 3 | September 7, 2013 08:00 |
Gamma differencing vs Venkatakrishnan limiter | ganesh | Main CFD Forum | 0 | December 3, 2010 12:52 |
Definition of limiter function for central dirrerencing scheme | sebastian_vogl | OpenFOAM Running, Solving & CFD | 0 | January 5, 2009 11:08 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
