No convergence issue
Old   October 7, 2015, 05:46
Default No convergence issue
kurdt89 is on a distinguished road
Hello everybody
I am trying to run a simulation of a reactor with the sst k omega, however I have some problems with convergence. I use the simpleFoam solver with 12 processors.
fvSolution
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
p
solver GAMG;
tolerance 1e-7;
relTol 0.0;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 1000;
mergeLevels 1;
    pFinal
        $p;
        tolerance        1e-7;
        relTol           0;
    "(U|k|omega|epsilon)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-8;
        relTol          0.0;
    "(U|k|omega|epsilon)Final"
        $U;
        relTol          0;
SIMPLE
    nNonOrthogonalCorrectors 1;
    residualControl
        p               1e-5;
        U               1e-5;
relaxationFactors
    fields
        p               0.1;
    equations
        U               0.1;
        k               0.05;
        omega           0.05;
    epsilon        0.1;
cache
    grad(U);
fvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //ddtSchemes
    default         steadyState;//Euler;//
gradSchemes
    default cellMDLimited Gauss linear 0.5;
    grad(U) cellMDLimited Gauss linear 0.5;
    grad(omega) cellLimited leastSquares 1.0;
    grad(epsilon) cellLimited leastSquares 1.0;
/*divSchemes
    div(phi,U) bounded Gauss linearUpwind grad(U); //bounded Gauss upwind; //
    div(phi,omega) bounded Gauss linearUpwind default; //bounded Gauss upwind; //
    div(phi,epsilon) bounded Gauss linearUpwind default; // bounded Gauss upwind; //
    div(phi,k) bounded Gauss linearUpwind default; //bounded Gauss upwind; //
    div((nuEff*dev(T(grad(U))))) Gauss linear; //Gauss linear; //
divSchemes
    div(phi,U)      bounded Gauss linearUpwindV grad(U); //
    div(phi,omega) bounded Gauss upwind; //bounded Gauss linearUpwind default; //
    div(phi,epsilon) bounded Gauss upwind; //bounded Gauss linearUpwind default; //
    div(phi,k) bounded Gauss upwind; //bounded Gauss linearUpwind default; //
laplacianSchemes
    default Gauss linear limited 1;
snGradSchemes
    default limited 0.777;
interpolationSchemes
    default         linear;
fluxRequired
    default         no;
    p;
kurdt89 is offline   Reply With Quote
Old   October 7, 2015, 05:59
U
  outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           uniform (0 0 0);
    volume_CFD
        type            fixedValue;
     inlet1
        type            fixedValue;
        value           uniform ( -3.1337499 0 -7.3826288);
    inlet2
        type            fixedValue;
        value           uniform (0 0 0); //(  3.1337499 0 -7.3826288);
k
boundaryField
    //- Set patchGroups for constraint patches
    outlet
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    volume_CFD
        type            kqRWallFunction;
    value        uniform 0;
    inlet1
        type            turbulentIntensityKineticEnergyInlet;
        intensity     0.038;
    value           uniform 1;
    inlet2
    intensity    0.038;
        value           uniform 1;
nut
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0.11;
boundaryField
    inlet1
        type            calculated;
    value        uniform 0;
    inlet2
        type            calculated;
    value         uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    volume_CFD
        type            nutUSpaldingWallFunction;
    value        uniform 0;
and checkMesh logFile
CMA: no RDMA devices found
[[30462,1],5]: A high-performance Open MPI point-to-point messaging module
was unable to find any relevant network interfaces:
Module: OpenFabrics (openib)
  Host: node045
Another transport will be used instead, although this may result in
lower performance.
|  \\    /   O peration     | Version:  2.2.x                                 |
Build  : 2.2.x-61b850bc107b
Exec   : checkMesh -parallel
Date   : Oct 07 2015
Time   : 11:44:56
Host   : "node045"
PID    : 11530
Case   : /CALCULS/maione1/CFDEM/tutorials/cfdemSolverIB/MeshMedia
nProcs : 12
Slaves :
11
"node045.11531"
"node045.11532"
"node045.11533"
"node045.11534"
"node045.11535"
"node037.14144"
"node037.14145"
"node037.14146"
"node037.14147"
"node037.14148"
"node037.14149"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
[node045:11519] 11 more processes have sent help message help-mpi-btl-base.txt / btl:no-nics
[node045:11519] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Time = 0
Mesh stats
    faces:            7085734
    internal faces:   4910183
    cells:            1891053
    faces per cell:   6.3435
    boundary patches: 5
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     1534837
    prisms:        51297
    wedges:        0
    pyramids:      0
    tet wedges:    1871
    tetrahedra:    69
    polyhedra:     302979
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            4   17986
            5   21538
            6   65018
            7   13858
            8   947
            9   137048
           10   596
           11   242
           12   29823
           13   917
           14   28
           15   11336
           16   194
           17   15
           18   3148
           19   4
           20   5
           21   260
           24   16
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking basic patch addressing...
                   Patch    Faces   Points
                  inlet1     4140     5053
                  inlet2     4122     5031
              volume_CFD   703841   852716
                  outlet     4338     4956
Checking geometry...
    Overall domain bounding box (-0.18 -0.18 -0.010004) (0.18 0.18 2.5)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (1.1211e-15 4.3906e-18 -7.4201e-18) OK.
    Max cell openness = 1.6134e-15 OK.
    Max aspect ratio = 32.143 OK.
    Minimum face area = 4.0523e-09. Maximum face area = 0.00031261.  Face area magnitudes OK.
    Min volume = 9.7672e-12. Max volume = 5.0375e-06.  Total volume = 0.22924.  Cell volumes OK.
    Mesh non-orthogonality Max: 65.006 average: 12.563
    Non-orthogonality check OK.
    Face pyramids OK.
 ***Max skewness = 19.309, 917 highly skew faces detected which may impair the quality of the results
  <<Writing 917 skew faces to set skewFaces
    Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
Finalising parallel run
attached there are also the residual.
the geometry consist on a pipe with many holes on its wall, releasing air in the main core of the reactor which is cylindrical
can somebody help me on that?
thank you all
Old   October 7, 2015, 06:06
I attach also some slice where you can see the main pipe on the left and the differents holes of injection
Old   October 8, 2015, 03:05
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
1) Can you make a better mesh without these skewed cells?
2) I don't really understand the geometry. Maybe it is not important, but could you try to post a picture of the whole thing, with highlighted inlets and outlets?
3) Can you post some log output?
4) In your residual plot you see some convergence finally at the end. Why did you stop calculating and what did you change at it=12000?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   October 8, 2015, 03:37
Philipp
As I understand it your solver settings are not very good. If there is no special reason you should not deactivate the relTol in SIMPLE. In SIMPLE it is not needed that every single linear equation is solved to a very low residual (what you do by just using the "tolerance"). This is, because you do the outer (SIMPLE-) iterations anyway and you just need the inner interations solved in a way that the outer algorithm remains stable. Thus, I usually use relTol=0.1 and set the tolerance to some very low value, such as 1e-18.
Secondly, you set the laplacian scheme to "limited 1", which means you use the corrected scheme. This is not the most stable one. Begin with "limited 0", this is the uncorrected scheme and if that works you can start to increase the numer to 0.3, 0.5, ...
Old   October 8, 2015, 05:58
thank you very much I will try your suggestions, i noticed there was something not right about the solvers. I will post here my results.
The problem is I do this mesh with snappy because is a really complicated mesh. Sorry I cannot post the entire mesh however the inlet is on the pipe on the left. Sorry I don't really remember what I've changed. I will post the log output when I go back to my office tomorrow. however thank you very much for your help, is really appreciated
Old   October 10, 2015, 17:00
Dongyue Li
sharonyue is on a distinguished road
Hello, Kurdt89,
Im not very familar with the your simulation. But looks like you are simulating a reactor(is there bubbles of droplets?). As we know SST k-omega is highly appropriate for strong adverse pressure gradient. In my simulations, such as stirred tanks, bubble columns, I just use k-epsilon.
Could you please share some experience with SST k-omega model in your reactor simulaiton?
Thanks.
My OpenFOAM algorithm website: http://dyfluid.com
By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam
We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html
sharonyue is offline   Reply With Quote
Old   October 12, 2015, 02:36
In my case the problem is that I cannot control the global value of y+ inside the whole thing and also that different regimes exhist, there are laminar regions in which the k-epsilon family would certainly crush (already tested).
So i use k omega sst with scalable functions, which is fine but highly unstable, I still have problems with convergence.
Convergence issue with continuity equation Jake FLUENT 8 June 6, 2018 03:41
convergence issue for transonic turbulent case aeroiitkgp SU2 5 May 12, 2015 16:44
convergence issue with turbulence mar Siemens 5 February 2, 2015 02:42
Convergence issue dhaya400 FLUENT 1 December 5, 2014 09:58
Convergence issue Jake FLUENT 3 June 30, 2005 04:12
