Calculate 3D bubble volume in twoPhaseEulerFoam in OF23x |
April 16, 2015, 09:17 |
Gitesh
Rep Power: 16 |
I am using twoPhaseEulerFoam in OF23x for simulations of two-phase steam water system. Is there any suggestions about how to calculate bubble volume in 3D case? With regards, GP |
November 7, 2015, 14:07 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I'll quote part of a recent PM you sent me:
As for calculating only in a particular region, this thread has part of the idea you need: http://www.cfd-online.com/Forums/ope...ume-field.html - using topoSet can be used either after the simulation is already done, because you can do several cell/face/point selection operations, as described in the main "topoSetDict" example: https://github.com/OpenFOAM/OpenFOAM...et/topoSetDict - namely in the location given by this command: Code:
echo $FOAM_UTILITIES/mesh/manipulation/topoSet/topoSetDict In addition, check in the main page: https://openfoamwiki.net/index.php/Contrib/swak4Foam - for the sections "FAQ", "Further information" and "Examples"
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
twoPhaseEulerFoam for modelling bubble plumes | davibarreira | OpenFOAM Verification & Validation | 0 | January 6, 2015 07:24 |
[ICEM] How to calculate the volume of mesh | BrolY | ANSYS Meshing & Geometry | 5 | February 7, 2013 12:08 |
calculate volume flow from a 2D simulation | SimonH. | OpenFOAM | 0 | October 27, 2009 04:39 |
calculate cell volume, center...? | Paul | Main CFD Forum | 5 | June 21, 2003 12:55 |
