uniformSet constructor error
Old   November 16, 2015, 09:49
Default uniformSet constructor error
Sandra
sabago is on a distinguished road
Dear OFers!
Hope all is good. I'm getting an error when using the uniformSet from components construct that should take 7 arguments. I'm using OF 2.3.0.
createFields.H:672:5: error: no matching function for call to ‘Foam::uniformSet::uniformSet(const char [15], Foam::fvMesh&, Foam::meshSearch, const char [9], Foam::point, Foam::point, int)’
createFields.H:672:5: note: candidates are:
In file included from xsofcFoam.C:36:0:
uniformSet.H:122:9: note: Foam::uniformSet::uniformSet(const Foam::word&, const Foam::polyMesh&, Foam::meshSearch&, const Foam::dictionary&)
         uniformSet
uniformSet.H:122:9: note:   candidate expects 4 arguments, 7 provided
uniformSet.H:110:9: note: Foam::uniformSet::uniformSet(const Foam::word&, const Foam::polyMesh&, Foam::meshSearch&, const Foam::word&, const point&, const point&, Foam::label)
         uniformSet
uniformSet.H:110:9: note:   no known conversion for argument 3 from ‘Foam::meshSearch’ to ‘Foam::meshSearch&’
uniformSet.H:43:7: note: Foam::uniformSet::uniformSet(const Foam::uniformSet&)
 class uniformSet
uniformSet.H:43:7: note:   candidate expects 1 argument, 7 provided
make: *** [Make/linux64GccDPOpt/xsofcFoam.o] Error 1
I know that there's a dictionary construct that takes 4 arguments. And that gives me the reverse error.
createFields.H:672:5: error: no matching function for call to ‘Foam::uniformSet::uniformSet(const char [15], Foam::fvMesh&, Foam::meshSearch, const char [9])’
         uniformSet
uniformSet.H:122:9: note:   no known conversion for argument 3 from ‘Foam::meshSearch’ to ‘Foam::meshSearch&’
         uniformSet
uniformSet.H:110:9: note:   candidate expects 7 arguments, 4 provided
So, which constructor should I use?
Best,
Sandra
sabago is offline   Reply With Quote
Old   November 16, 2015, 10:43
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Maybe you can also post how you are calling constructor (i.e. part of createFields.H)? In both cases you have posted, the third argument causes error. So the question is how do you pass that third argument.
alexeym is offline   Reply With Quote
Old   November 16, 2015, 11:01
Sandra
Hello again,
You're right, Alexey, meshSearch(mesh), seems to be the problem but how to fix it...
uniformSet line
        "jcLine,
        mesh,
        meshSearch(mesh),
        "axis"
        point(5e-5, 0, 2.5e-5),  // start point
        point(5e-5, 5e-5, 2.5e-5),  // end point
        20  // density of points on the line
Sandra
Old   November 16, 2015, 11:13
Alexey Matveichev
Is it a problem of copy-paste or there is really no closing quote after jcLine? Also I did not find comma after "axis" in your snippet.
You can surely try to create object meshSearch myLovelyMesh(mesh) and then pass it to uniformSet constructor instead of creating object on the fly. I.e. your code should be something like:
    meshSearch myLovelyMeshSearch(mesh);
    uniformSet line
        "jcLine",
        mesh,
        myLovelyMeshSearch,
        "axis",
What compiler/OS do you use? I have tested constructor with clang-7.0.0/Darwin, gcc-5.1.1/Linux and everything compiles quite fine.
Old   November 16, 2015, 11:29
Sandra
Originally Posted by alexeym View Post
    uniformSet line
        "jcLine",
        mesh,
        myLovelyMeshSearch,
        "axis",
my bad, I missed the closing quote but yeah, was actually missing the comma on line 4 as I had commented the remaining 3 arguments out but forgot to include it when I uncommented.
And thanks, your suggestion worked like a charm.
I'm using Ubuntu 4.2. and gcc-4.8, g++-4.8.
Sandra
