about time step and end time
Old   November 18, 2015, 11:11
Default about time step and end time
shukai
dingshukai is on a distinguished road
I am beginner for stimulation by software. May be it is easy for you, but I can't understand why I need set end time. If I set end time, how can I know whether the stimulation is finished, because the process will be end at time I set.
dingshukai is offline   Reply With Quote
Old   November 19, 2015, 02:21
akidess's Avatar
Anton Kidess
For a transient case, your question is trivial, so I assume you are interested in steady state solutions. In that case, think of endTime as a maximum amount of iterations you want to run. The simulation may actually stop before endTime (=maxIters) if you use residualControl. Ideally, you should look at convergence of physical quantities to judge your convergence, e.g. drag or a temperature or similar.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   November 19, 2015, 06:22
shukai
Could you explain how to control it by residual control or there is some literature about it, Because I can't find it. Thank you for you reply
Old   November 19, 2015, 07:05
akidess's Avatar
Anton Kidess
Most simpleFoam tutorials can serve as an example, e.g. pitzDaily.
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
