November 25, 2015, 04:59 |
FSI simulation of compressible flow
Florian Nguyen
Rep Power: 10 |
Hi there,
I am trying to model a cylindrical tube equipped with reed valves, assuming a transient compressible flow. I basically want to run a shock tube simulation and study the motion of the valves, hence my interest in FSI. Although I am not very proficient at OpenFOAM, it looks like no current solver can manage compressible FSI. I was hoping someone could give me some advice at this point : - Could you recommend compressible solvers that I could combine to icoFsiFoam to obtain a compressible FSI solver ? - Also, I saw that icoFsiFoam had issues with small time steps. Is is a Courant number problem or really a time step problem ? I'm not quite sure I understood the answers I saw in other posts. Could somebody please enlighten me on the subject ? - Do you think there is a better solution than using icoFsiFoam ? Any help would be most welcome ! Thanks for your help, Florian Last edited by Awak; November 26, 2015 at 01:22. |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 06:48 |
parametric study in flow simulation | topaz | FloEFD, FloWorks & FloTHERM | 1 | July 13, 2015 08:50 |
Need help with HELYX-OS Compressible Flow Simulation | badboyz31 | OpenFOAM Pre-Processing | 2 | February 16, 2014 22:25 |
how to set BC for compressible flow target mass flow rate | foolboy007 | FLUENT | 1 | April 4, 2012 03:24 |
Simulation of air flow inside valve - FSI? Help! | farianka | Main CFD Forum | 0 | April 17, 2011 16:30 |
