"No such file or directory exists" error
Old   November 26, 2015, 11:56
Unhappy "No such file or directory exists" error
Mahendra
mahendrark is on a distinguished road
Hey guys!
Just installed OpenFOAM-3.0.0 in Ubuntu 14.04 in my PC. Then, I tried running the Lid Driven Cavity Flow tutorial. But this error keeps getting in the way and prevents the following line from getting executed on Terminal:
 cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
I keep getting this message when I execute the above line:
bash: cd: /tutorials/incompressible/icoFoam/cavity: No such file or directory
I checked the files in the directory and made sure they are in proper order. I've included the screenshot of the directory.
(http://imgur.com/Od6O5CE)
Can someone help me with setting this right?
Thanks
mahendrark is offline   Reply With Quote
Old   November 28, 2015, 15:42
Retired Super Moderator
Bruno Santos
Quick answer: It seems like the OpenFOAM shell environment is not active. My guess is that you followed these instructions: https://openfoamwiki.net/index.php/I...u#Ubuntu_14.04
If you did, then whenever you start a new terminal you should run:
of300
If it doesn't work, please provide more details about which installation instructions you followed. Because if you followed the official instructions from source, you should run:
source $HOME/OpenFOAM/OpenFOAM-3.0.0/etc/bashrc
file path bug, openfoam
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
