baffles pressure difference
Old   January 15, 2016, 06:02
Default baffles pressure difference
Caro
will_ca is on a distinguished road
I'm trying to create two areas with different pressures that are separated by a baffle. I set the boundary condition for pressure at the baffle to zeroGradient, but when I look at it in paraview I get a steep gradient in pressure over the baffle as in the first picture. I want to use the baffle so I can simulate heat transfer using thermalbaffles1D.
If I mesh the two areas separately and then use mergeMesh, the pressure looks as I expect it to look (second picture).
The pressure boundary condition is the same for both cases and the patch is defined as wall in the boundary file for both cases.
Does anyone know why I get the different behaviour?
I appreciate any help,
Caro
will_ca is offline   Reply With Quote
baffle, pressure
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 16:29
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Fluid flow caused by initial pressure difference perry.fox FLUENT 1 December 24, 2010 08:42
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
