January 24, 2016, 05:38 |
chtMultiRegionSimpleFoam - Own Case
Rep Power: 10 |
I am working with OpenFoam since last August and used it for Lagrangian particle tracking and incompressible cases. Now I want to move on. My topic of my Masterthesis is a simulation of a hot wire application in the exhaust side of a fuel cell. However, this wire is hot (~180°C constant temperature) and I want to figure out how the heat transfer to the fluid is, dependent on its composition. Therefore I decided that chtMultiRegionSimpleFoam is the way to go. I started up with the heat exchanger case and the planeWall2D case. So my case consists of tow blocks: 1. Solid block that should be hot (red block in the figure) 2. Fluid block with inlet and outlet (blue block in the figure, second figure shows position of inlet and outlet) The meshing works, I did it based on snappyHexMesh, as I want to use that for my real project. I am failing now at setting up the boundaries. Before coming to the real boundaries the big question is which files do I need to simulate this a case? In 0/solid: - T (temperature) in 0/flow: - p - p_rgh - T - U In both folders is as well the file "cellToRegion". Do I need that? When my case finally works, I would like to upload it here, as I know there is a high interest in this solver, but it is as well a pain in the a** to set up. Thank you! Hoping for an answer. Best |
January 25, 2016, 11:44 |
Update
Rep Power: 10 |
I set up boundaries as far as I could until now. Now I have a problem with the temperature files. When I start my simulation it crashes after solving the velocity and gives this error: Code:
Time = 1 Solving for fluid region flow DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.009170221, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.006990952, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.01200734, No Iterations 1 -->FOAM FATAL ERROR: Attempt to cast type zeroGradient to type compressible::turbulentTemperatureCoupledBaffleMixed From function refCast<To>(From&) in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/typeInfo.H at line 114. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::compressible::turbulentTemperatureCoupledBaffleMixedFvPatchScalarField::updateCoeffs() at ??:? #3 Foam::mixedFvPatchField<double>::evaluate(Foam::UPstream::commsTypes) at ??:? #4 Foam::mixedEnergyFvPatchScalarField::updateCoeffs() at ??:? #5 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::updateCoeffs() at ??:? #6 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:? #7 ? at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? Aborted (core dumped) The T file for the fluid (called flow): Code:
internalField uniform 300; boundaryField { inlet { type fixedValue; value uniform 300; } outlet { type zeroGradient; value uniform 0; } walls { type zeroGradient; value uniform 300; } flow_to_heater { type compressible::turbulentTemperatureCoupledBaffleMixed; value uniform 400; neighbourFieldName T; kappa fluidThermo; kappaName none; Tnbr T; } } Code:
internalField uniform 400; boundaryField { inlet { type zeroGradient; value uniform 400; } outlet { type zeroGradient; value uniform 400; } walls { type zeroGradient; value uniform 400; } heater_to_flow { type zeroGradient; value uniform 400; } flow_to_heater { type compressible::turbulentTemperatureCoupledBaffleMixed; neighbourFieldName T; kappa solidThermo; kappaName none; value uniform 400; } } Thank you very much! Best |
January 25, 2016, 12:24 |
Karl Lindqvist
Dear Gerrit,
Your question regarding boundary conditions was answered here previously on this forum - the interface patch must be specified consistently for both regions. For the files, OpenFOAM will quickly tell you if any files are missing once you try running the solver. I believe a (dummy) pressure file is needed in the solid region. The cellToRegion files are superfluous as far as I know since the actual grid is stored in the constant/<region>/polyMesh folder. Best regards, Karl |
January 25, 2016, 14:09 |
Rep Power: 10 |
Hey Karl,
thanks for the answer! I did a really stupid mistake: I inserted the wrong patch name .. However, now I can at least run the case some iterations until it breaks up. I will try to figure that out as well! Thanks for the help! Greetings to Norway from Denmark! Best Gerrit |
January 27, 2016, 08:50 |
Rep Power: 10 |
my case is running now. I hope someone else can use it as well to learn how to run this kind of simulations. If there are any questions or critics, please let me know - I will try to respond to this. By the way: I used OpenFOAM 3.0.1. Best Gerrit |
MRFSimpleFoam wind turbine case continuity error | ysh1227 | OpenFOAM Running, Solving & CFD | 1 | August 16, 2016 09:25 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
MRFSimpleFoam wind turbine case diverges | ysh1227 | OpenFOAM Running, Solving & CFD | 2 | May 7, 2015 10:13 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 11:20 |
