OpenFoam 3.0.x Moving Solid Body Through Mesh |
Leonard Cassady
Rep Power: 10 ![]() |
I am currently running compressibleInterFoam where I have a jet of fluid (water or air, depending on the case) flowing upward into a stagnant body of water. I would like to add a solid body with a pre-programmed trajectory into the body of water. The body can move at a constant velocity in a straight line. What is the best way to solve this problem? The volume is roughly 20meter per side and I would like the body to move 2 to 4 meters near the center of the volume. I don't think that the standard OpenFoam dynamic mesh tools work because I'm not changing the outer volume. I'm thinking that either an immersed boundary method or re-meshing using dynamicFvMesh. Are examples of either of these options available for Openfoam 2.3 or 3.0? I have learned that foam-extend 3.2 has some solvers with immersed boundary methods. How difficult would it be to fit compressibleInterFoam with immersed boundary methods? Thanks, Leonard Cassady Last edited by im_lenny; January 27, 2016 at 10:55. Reason: Specifically referencing foam-extend 3.2 |
Rep Power: 12 ![]() |
I do not know if you still need the information you requested, but you can find here an instruction how to add immersedBC compatibility to any solver (foam-extend3.2) https://openfoamwiki.net/index.php/E...mersedBoundary |
dynamic mesh, dynamicfvmesh, foam-extend-3.2, immersed boundary method, openfoam 3.0.0 |
moving a cold solid body into stationary hot air for heat transfer | shyamgarg | Main CFD Forum | 3 | December 26, 2019 22:41 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
salome, openfoam and moving mesh | prhlava | OpenFOAM Running, Solving & CFD | 8 | November 9, 2009 08:59 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
