OpenFoam 3.0.x Moving Solid Body Through Mesh
Like Tree1Likes
  • 1 Post By hxaxtma
Old   January 26, 2016, 11:33
Default OpenFoam 3.0.x Moving Solid Body Through Mesh
Leonard Cassady
im_lenny is on a distinguished road
I am currently running compressibleInterFoam where I have a jet of fluid (water or air, depending on the case) flowing upward into a stagnant body of water. I would like to add a solid body with a pre-programmed trajectory into the body of water. The body can move at a constant velocity in a straight line. What is the best way to solve this problem? The volume is roughly 20meter per side and I would like the body to move 2 to 4 meters near the center of the volume.
I don't think that the standard OpenFoam dynamic mesh tools work because I'm not changing the outer volume. I'm thinking that either an immersed boundary method or re-meshing using dynamicFvMesh. Are examples of either of these options available for Openfoam 2.3 or 3.0?
I have learned that foam-extend 3.2 has some solvers with immersed boundary methods. How difficult would it be to fit compressibleInterFoam with immersed boundary methods?
Thanks,
Leonard Cassady
Last edited by im_lenny; January 27, 2016 at 10:55. Reason: Specifically referencing foam-extend 3.2
im_lenny is offline   Reply With Quote
Old   March 1, 2016, 10:27
hxaxtma is on a distinguished road
I do not know if you still need the information you requested, but you can find here an instruction how to add immersedBC compatibility to any solver (foam-extend3.2)
https://openfoamwiki.net/index.php/E...mersedBoundary
shincoast likes this.
hxaxtma is offline   Reply With Quote
dynamic mesh, dynamicfvmesh, foam-extend-3.2, immersed boundary method, openfoam 3.0.0
moving a cold solid body into stationary hot air for heat transfer shyamgarg Main CFD Forum 3 December 26, 2019 22:41
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 08:59
