September 9, 2020, 16:40 |
Dakota - Fork application failure
Carl Reilly
Rep Power: 15 |
I am currently struggling to resolve the below error: Warning: analysis driver "rosenbrock" not found. Fork application failure, aborting. System error message: Permission denied The interface definition of the input file is: interface analysis_drivers = 'rosenbrock' fork parameters_file = 'params.in' results_file = 'results.out' OS: Ubuntu 18.04.4 LTS (running on windows power shell) Dakota 6.12.0 Example problem: Files copied from DAKOTA/examples/user/rosen_syscall.* Code:
carl@DESKTOP-SDA6914:~/OpenFOAM/carl-7/run/dakotaTutorial/rosenbrock/rosenSyscall$ ls -l total 92 -rwxrwxrwx 1 carl carl 0 Sep 9 10:07 dakota.rst -rwxrwxrwx 1 carl carl 65 Sep 9 10:07 rosen_syscall.dat -rwxrwxrwx 1 carl carl 5404 Sep 4 13:15 rosen_syscall.dat.sav -rwxrwxrwx 1 carl carl 740 Sep 4 13:15 rosen_syscall.in -rwxrwxrwx 1 carl carl 1474 Sep 9 10:07 rosen_syscall.out -rwxrwxrwx 1 carl carl 61623 Sep 4 13:15 rosen_syscall.out.sav -rwxrwxrwx 1 carl carl 601 Sep 9 10:07 rosen_syscall.stdout -rwxrwxrwx 1 carl carl 5265 Sep 4 13:15 rosen_syscall.stdout.sav [/HTML] # Dakota Variables INSTALL_DIR=/home/carl/DAKOTA/dakota-6.12.0 export PATH=$PATH:$INSTALL_DIR/bin:$INSTALL_DIR/test export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$INSTALL_DIR/bin:$INSTALL_DIR/lib # All versions, to use the dakota.interfacing Python module: export PYTHONPATH=$PYTHONPATH:$INSTALL_DIR/share/dakota/Python export PATH="/root/perl5/perlbrew/perls/perl-5.26.1/bin:$PATH" export PATH="$PATH:." [/HTML] Background: I installed Dakota for the first time, building it from source files. I ran the test suite and it seemed to work. I have then copied the example rosenbrock problems from the examples folder. The examples using the "direct" interface run correctly. But the problems using the simulation interface do not. I also have another simple Dakota example that uses the simulation interface. I wanted to get this running, however, this results in the same problem as with the example case. Therefore I'm focusing on getting the example case running in the hope that the solution will fix this case as well. Investigations: I've run the test suite and it seems to work I've tried all the direct interface training tutorials - They work I've tried running the problem from the original examples directory in case the file paths were missing. This gave the same error. Any help would be appreciated. |
September 10, 2020, 07:56 |
Tobias Holzmann
Rep Power: 51 |
without reading your whole post, you can easily take the interface provided within my tutorials on my website. I guess you should be able to resolve your problem while comparing the cases or directly use and rewrite the interface. This is actually not an OpenFOAM problem
Keep foaming, Tobias Holzmann |
September 10, 2020, 12:37 |
Carl Reilly
Rep Power: 15 |
Tobi,
Agreed, this is not an OpenFoam issue, rather a Dakota one, however, I was hoping someone here might have the knowledge to assist. The Dakota support system is not as well developed as OF (at least for public users). I've sent a support request to the Dakota user group, but as I'm not part of a government lab I'm likely bottom of the pile for support. I have your example (very helpful) and I get the same error with your case, as with the simulation interface examples from the Dakota tutorials, therefore I suspect its some system/installation issue. I'm just out of ideas and expertise as to what it is or how to trace it. |
September 10, 2020, 17:40 |
Carl Reilly
Rep Power: 15 |
I've managed to get dakota to run the tutorial cases by deleting and re-installing dakota 6.12.0.
I'm not sure what the difference was in the install. The only thing that I can think of is that during trying to debug the first installation I had to install some additional libraries/packages. maybe, these being present at the start in some way fixed the installation the second time around. |
August 11, 2023, 13:10 |
#5 | |
Rep Power: 17 |
Basically, when Dakota comes to forking the parent process for the individual runs, i get the Code:
Fork application failure, aborting. System error message: Permission denied So i was wondering, 1) did the OP install the RELH binaries, or compile his own? Sounds like he is on Ubuntu but used the precompiled binaries 2) Can anyone else think of why the OS might be preventing the fork process (with the permission denied) message? Perhaps there is something special on Ubuntu that doesnt let the app make the fork syscall? Any help would be greatly appreciated. TIA Cheers JB |
August 11, 2023, 13:33 |
#6 | |
Rep Power: 17 |
simulator_script.sh Glad is was something simple and not deeper in the code / compilation. |
OpenFOAM - Dakota coupling/Issues with Dakota parameters file | ilaj | OpenFOAM Programming & Development | 0 | February 4, 2020 12:34 |
Error in compute process - No Active Application | yetlyg | FLUENT | 8 | October 27, 2018 22:30 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[OpenFOAM] could not open file .vtk in paraview | ali_atrian | ParaView | 8 | August 27, 2014 10:31 |
