Different velocity write method results in different readings
Old   February 7, 2016, 03:05
Default Different velocity write method results in different readings
J.-H. Wang
f0208secretx is on a distinguished road
I noticed that using the following function call to dump velocity will give a slightly different reading than the normal write (which is controlled by the keyword "writeInterval" in the dict). I assume its because one is done before and the other is done after the current iteration? Can someone with more experience answer this? I don't want to write all the fields because in my postprocessing I only need velocity. Thanks.
Version is OF2.4.0 on Ubuntu.
functions
    velocityDump
        type                writeRegisteredObject;
        functionObjectLibs  ("libIOFunctionObjects.so");
        //outputControl        outputTime;
        //outputInterval       1;
        outputControl       adjustableTime;
        writeInterval       0.0001;
        objectNames
             "U"
f0208secretx is offline   Reply With Quote
Old   February 8, 2016, 15:24
J.-H. Wang
I wonder if anyone has some insights about this?
Choice of method and verification of results pace Main CFD Forum 4 March 19, 2015 14:24
Vertical Velocity at results ejdrlqja CFX 1 March 10, 2015 04:06
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
is there any method give node based velocity BC? daniel FLUENT 2 July 18, 2006 21:21
howto write step velocity profile with expressions prabhu CFX 2 May 23, 2006 09:41
