Commands Priority for runing a case
Old   February 16, 2016, 04:18
Question Commands Priority for runing a case
Mohsen
mohsen.boojari is on a distinguished road
Hi Everyone,
I have faced some test cases that they don't have Allrun script and consist of several different scripts like blockMeshDict, decomposeParDict, topoSetDict, snappyHexMesh and ...
I don't know which one should i run first and continue with others.
for example in a simple case I know we should use (BlockMesh-icoFoam-ParaFoam). but for professional ones what would it be?
does anyone know the priority of commands in openFoam???
thanks
mohsen.boojari is offline   Reply With Quote
Old   February 16, 2016, 05:14
Joćo Ferreira
jmdf is on a distinguished road
I can't list all the command in terms of priority of use although you should do something like:
1. Mesh builder (blockMesh, snappyHM,..);
2. Commands who "prepare" the mesh such as topoSet, splitMeshRegions (if needed, etc);
3. Pre-processing such as changeDictionary;
4. decomposePar - if running in parallel
5. Solver you are using;
6. reconstructPar - if running in parallel;
7. paraFoam or any other post-processing tool;
Hope it helps!
jmdf is offline   Reply With Quote
Old   February 16, 2016, 05:27
Mohsen
Originally Posted by jmdf View Post
Hope it helps!
Hi
thanks for your useful reply. it helps so much. but do you know any resources that have a command list or some more detailed explanations about this subject?
Old   February 16, 2016, 05:34
Joćo Ferreira
No I don't and that is a little hard to find.
Anyway when you find a command you want to use, try to understand what it does and fit it on the previous list. It's the best advice I can give you, perhaps someone else has a better way to do it!
Old   February 16, 2016, 05:36
Mohsen
yes, you're right. thanks anyway my friend
scripts, solving
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
MRFSimpleFoam wind turbine case diverges ysh1227 OpenFOAM Running, Solving & CFD 2 May 7, 2015 10:13
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 11:20
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
