slip & noslip boundary conditions are wrong on dynamic mesh
Old   February 17, 2016, 03:31
Default slip & noslip boundary conditions are wrong on dynamic mesh
Olaf Schiemann
oschi is on a distinguished road
I have a small test case, which models the water flow inside a "bouncing cube", a rectangular mesh growing/shrinking periodically in the horizontal/vertical direction.
The motion of the walls is not transferred to the water, whatever boundary condition I use for the velocity (slip, no slip, fixedValue (0 0 0 )).
Do other boundary conditions or solvers exist which correctly interprete the slip or noslip conditions such that no relative (normal) velocity occurs between the moving wall and the fluid inside?
I am testing with rhoPimpleDyMFoam of OpenFOAM 2.4.0. You will definitely help me as well, if you know of a solution using another solver or OpenFOAM version.
Greetings
Olaf
oschi is offline   Reply With Quote
Old   February 17, 2016, 07:59
JNSN's Avatar
Jan
JNSN is on a distinguished road
Hi Olav,
try movingWallVelocity
Best regards,
Jan
JNSN is offline   Reply With Quote
Old   February 17, 2016, 10:32
Olaf Schiemann
Hi Jan,
thank you very much for your reply. Apparently, not the fluid velocity boundary condition was the problem, but the pointMotionUx boundary condition does not work quite as I need.
I am testing now with the incompressible/pimpleDyMFoam/movingCone tutorial. Changing the movingWall boundary in 0/U as follows works as expected:
    movingWall
        type            movingWallVelocity;
        value           uniform (0 0 0);
        //type          fixedValue;
        //value         uniform (1 0 0);
However, this simulation succeeds only if 0/pointMotionUx for movingWall is set to "uniformFixedValue=1". I had attempted first to use groovyBC and then my own, custom class (derived from fixedValuePointPatchField) instead of the uniformFixedValue. Below is an example, which uses groovyBC to express the same pointMotionUx==1, but this example fails, because the mesh is distorted after a few steps:
    movingWall
        //type          uniformFixedValue;
        //uniformValue  constant 1;
        type            "groovyBC";
        value           uniform 1;
        valueExpression "toPoint(1)";
Running this example translates the moving patch correctly, but the remaining mesh motion is not solved correctly (the internal mesh doesn't move).
Can you imagine a reason, why this fails, whereas the uniformFixedValue example succeeds?
Greetings
Olaf
Old   February 18, 2016, 12:52
Olaf Schiemann
Originally Posted by JNSN View Post
Hi Olav,
Best regards,
Jan
Although movingWallVelocity worked if pointMotionUx is "constant 1", there is a bug if pointMotionUx is variable in time.
I have attached a case file to reproduce the problem in this thread:
http://www.cfd-online.com/Forums/ope...implement.html
Greetings
Olaf
Centrifugal fan j0hnny CFX 13 October 1, 2019 13:55
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Radiation interface hinca CFX 15 January 26, 2014 17:11
