March 1, 2016, 20:02 |
What is the adequate solver and tutorial?
Rep Power: 10 |
Dear Sir,
I am going to start to cope with the calculation of the heat exchanger including phase change. More specifically, for a vaporiser of double tube type heat exchanger, I want to calculate the vaporisation of the liquid flowing through the inner tube caused by the heat transfer from warm water flowing through the outer tube. Could you tell me what is the adequate solver and tutorials for the calculation of "heat exchanger", "heat-transfer-driven vaporisation"? I have used solvers for gas phase not including energy equation, and have never used such a liquid, heat transfer solver. I would appreciate if you give some advise. Sincerely, KeiJun |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM Running, Solving & CFD | 17 | December 3, 2014 19:41 |
which solver (tutorial) is for heat transfer between fluid and solid? | mxylondon | OpenFOAM | 3 | December 14, 2012 19:54 |
Flow through pipe bend tutorial - Solver Error | sledfreak17 | CFX | 4 | May 16, 2012 10:29 |
Why run the solver twice ("cavity" tutorial section 2.1.8.2)? | a330 | OpenFOAM Running, Solving & CFD | 0 | February 27, 2012 11:15 |
Solver problem in Oscillating Plate tutorial | vovogoal | CFX | 1 | November 22, 2011 09:54 |
