error - help me?
Old   November 19, 2017, 18:47
Default error - help me?
xirtam's Avatar
Fábio
xirtam is on a distinguished road
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'laplacian(K,' on line 37 and ending at line 53"
file: C:/OpenFOAM/17.06/ffrei-dev/run/case/system/fvSchemes at line 53.
From function void Foam:rimitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&)
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 189.
FOAM exiting
xirtam is offline   Reply With Quote
Old   November 20, 2017, 04:31
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
We need your fvschemes file.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   December 1, 2017, 07:47
Jerry
dansan is on a distinguished road
hi.
I want to modify the salarTransportFoam to solve another problems.The code like this:
fvScalarMatrix VaEqn
- fvm::laplacian(Per, Va)
F*(Z1*C1+Z2*C2)
The fvSchemes file like this:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
laplacianSchemes
default none;
laplacian(Per, Va) Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
when runing ,it displayed the following mistake:
"ill defined primitiveEntry starting at keyword 'laplacian(Per,' on line 36 and ending at line 57"
I need help very much. Thank you very much.
dansan is offline   Reply With Quote
