Floating point exception
Like Tree2Likes
Old   April 11, 2016, 06:43
Default Floating point exception
cristian.arbe's Avatar
Cristian Ariza
cristian.arbe is on a distinguished road
Hello all,
I am relatively new to OpenFoam and I am trying to simulate a photoreactor on incompressible turbulent flow at steady-state. I copied most of the code of the pitzDaily model from the tutorials adjusting all the parametres for my case. When running the case in parallel I get the following error:
mpirun noticed that process rank 7 with PID 3333 on node XXXXX exited on signal 8 (Floating point exception).
Commands I used:
decomposePar
mpirun -n 16 renumberMesh -overwrite -parallel
mpirun -np 16 simpleFoam -parallel
reconstructPar -latestTime
Things I did:
  • deltaT: I tried reducing the deltaT to a point of a Courant number of 0.5 and still getting the error.
  • Lack of memory: running on a workstation of 64GB of RAM and the used RAM does not even go above 1.5 GB.
  • Laminar flow: simulation succeeds on calculating the laminar case.
I believe there is some bad boundary condition but I cannot find where it is.
Here is a 7z file with the case: https://mega.nz/#!Z1JTjZoY!YSOBNCHdW..._ArkRD3O1SmzvU
cristian.arbe is offline   Reply With Quote
Old   April 11, 2016, 11:27
Cristian Ariza
Succeeded by simulating the case in laminar flow but turbulent still does not work.
Old   April 12, 2016, 05:26
Tobi's Avatar
Tobias Holzmann
you can try to use the laminar pre-calculation for your turbulent calculation. Normally, I suppose that you made a mistake in the set-up of your turbulence variables k, epsilon or omega. For your 7z file we need some key! "To access this folder/file, you will need its Decryption key.
If you do not have the key, contact the creator of the link."
Keep foaming,
Tobias Holzmann
Old   April 12, 2016, 06:38
Cristian Ariza
Sorry about the file! I edited the post so that the link includes the key to access.
For the k and \epsilon parametres I used the formulas:
k=\frac{3}{2}\left(UI\right)^{2}
\epsilon=C_{\mu}\frac{k^{\frac{3}{2}}}{l}
Old   April 12, 2016, 06:51
Tobi's Avatar
Tobias Holzmann
Use the correct boundary conditions! Do not set it by yourself.
Keep foaming,
Tobias Holzmann
Old   April 12, 2016, 07:00
Cristian Ariza
I am sorry, what do you mean by using the correct boundary conditions? This is how my k and epsilon files look like respectively:
internalField   uniform 8.7277e-006;
boundaryField
    fluidInlet
        type	fixedValue;
		value	uniform 0.0090220;
	fluidOutlet
        type	zeroGradient;
	fluidCylinder
        type	kqRWallFunction;
        value	uniform 8.7277e-006;
	fluidRefinement
internalField   uniform 3.0534e-006;
boundaryField
	fluidInlet
        type            fixedValue;
		value           uniform 0.33827;
	fluidOutlet
        type            zeroGradient;
	fluidCylinder
        type            epsilonWallFunction;
        value           uniform 3.0534e-006;
	fluidRefinement
I set different values for Cylinder and Inlet/Refinement since they have different diametres and velocities.
Old   April 12, 2016, 07:30
Tobi's Avatar
Tobias Holzmann
What about:
turbulentIntensityKineticEnergyInlet
mixingLength...DissipationRate
Keep foaming,
Tobias Holzmann
Old   April 14, 2016, 09:44
Cristian Ariza
Originally Posted by Tobi View Post
What about:
Tried changing the conditions as you suggested but still getting the error
mpirun noticed that process rank 6 with PID 2520 on node XXXX exited on signal 8 (Floating point exception).
I assume the mixing length refers to this?
Old   April 14, 2016, 10:06
Tobi's Avatar
Tobias Holzmann
the mixingLength is okay. So I will check our case now (:
Keep foaming,
Tobias Holzmann
Old   April 14, 2016, 10:32
Tobi's Avatar
Tobias Holzmann
some hints:
  1. For the first try use Gauss upwind for k, epsilon
  2. You are not really underrelaxing
k  0.2
epsilon 0.2
U 0.4
p 0.3
Try again you will see it should work and then you will find the problem cells
You sill will get a bounding problem:
bounding epsilon, min: -0.00074722 max: 1053.16 average: 1.14941
Thats due to your mesh. The inlet and outlet patches are not good. Also your nCellsBetweenLevels should be increased and the inlet and outlet patch should be refined 1 level more. The transition between inlet/outlet patches to your refine walls should be smooth. I did not check if you also have layers in the refinement walls - skip that at the beginning.
Cheers.
Keep foaming,
Tobias Holzmann
Old   April 15, 2016, 04:47
Cristian Ariza
I'm trying to do all the changes you suggested, although I wanted to ask, when you talk about inlet and outlet, you refer to the tubes or the actual patches? Since the inlet/outlet patches only refer to the surface of I/O not the whole inlet tube.
Thank you very much for your time!
Old   April 15, 2016, 05:02
Tobi's Avatar
Tobias Holzmann
I refer only to the patches. The outlet and inlet patches have some "bad" faces at the connection between your refinement patch and inlet/outlet patch. These faces are not aligned correct.
Keep foaming,
Tobias Holzmann
Old   April 15, 2016, 05:11
Tobi's Avatar
Tobias Holzmann
SNAP controls.
increase the nSolveIter
decrease tolerance
decrease nFeatureIter
CASTELLATED controls.
increase nCellsBetween
At least I am not a fan of featureEdge refinement. I think there was some new keyword about tolerance etc. Using this, you could get troubles (see tutorial on my homepage) if the backgroundMesh is aligned with one patch/feature edge - I think in your case it is okay.
TRIANGULATED SURFACE (STL)
I will never use STL's that will not be closed or exported by CAD software. The triangulation is very bad. In your case the STL is not waterproof. My experience after 6 years: Never use an non-waterproofed STL and snappyHexMesh. It could work or otherwise you could get some unexpected results (sometimes) especially if the gaps are bigger than the cells.
So a few things to do.
Keep foaming,
Tobias Holzmann
Old   April 15, 2016, 05:16
Tobi's Avatar
Tobias Holzmann
One thing left.
surfaceFeatureEdges... please check it before using them. See attachment. Due to the fact that your STL's are not identical at the interfaces (same amount of points at the same locations) the featureEdges will also be different (attachment). So my question to you, which one should snappy use now? In addition, some feature edges are not closed etc...
Correct this too!
Keep foaming,
Tobias Holzmann
Old   April 15, 2016, 05:40
Cristian Ariza
The STL files are exported from a model from SolidWorks I made myself and it was fine before exporting. What is your suggestion to import the geometry then?
Old   April 15, 2016, 05:48
Tobi's Avatar
Tobias Holzmann
CAD files are okay. But after exporting single surfaces you will never get a closed surface. Just open paraview and load your STL. Show the edges and you wlil see.
Keep foaming,
Tobias Holzmann
Old   April 15, 2016, 06:23
Cristian Ariza
So should I stick with the STL files even if there are some errors or is there something I can do to fix it?
Old   April 15, 2016, 06:26
Tobi's Avatar
Tobias Holzmann
Export your geometry as STEP, open it with SALOME, create your different patches (create groups), go to mesh module and mesh the different patches like you want. Keep in mind that the interfaces should be identical triangulated. Export the surfaces as STL and combine them like
cat *.stl > mySTL.stl
surfaceCheck mySTL.stl
Then you should have a waterproofed STL.
PS: If you stick your STL together, you would end up with a non closed STL -> bad. This happens always if you export out of CAD software (ALWAYS). You can export the whole geometry, then you get a closed STL but then you do not have regions // single patches (thats the problem).
Keep foaming,
Tobias Holzmann
Old   April 15, 2016, 09:37
Cristian Ariza
I tried installing and running SALOME but I get the error
ImportError: No module named site
followed the README and set the environment variables but still getting the error.
Edit: solved by downloading the generic binaries instead of Ubuntu ones.
Old   April 15, 2016, 10:12
Cristian Ariza
So what you are saying is to export the STL geometry from SALOME or to actually mesh the model on SALOME and export the mesh?
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 11:43
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 04:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 13:56
floating point exception [invalid operation] jubair073 STAR-CCM+ 5 April 24, 2015 13:05
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 10:21
