MapFields doesnt work in the "counterFlowFlame2D" tutorial case
Like Tree2Likes
  • 2 Post By wyldckat
Old   April 12, 2016, 10:29
Default MapFields doesnt work in the "counterFlowFlame2D" tutorial case
christos panagopoulos
panachristos is on a distinguished road
Hello Foamers,
I am a new member in this community and this is my first post/thread.
To begin, i ran the case 'counterFlowFlame2D' from the tutorials and it is okay.
Then, i want to refine the mesh so i did the followings:
1)create a directory called 'counterFlowFlame2DFine'
2)copy into it 'constant' and 'system' from the original case
3)in blockMeshDict i refined the mesh from (100 40 1) to (200 80 1)
Then i ran the case by typing:
a)blockMesh
b)mapFields ../counterFlowFlame2D -consistent -sourceTime 'latestTime'
And i am getting the following message:
Create databases as time
Case   : ../counterFlowFlame2D
nProcs : 1
Source time: 0.2
Target time: 0
Create meshes
Source mesh size: 4000  Target mesh size: 16000
Consistently creating and mapping fields for time 0.2
Creating mesh-to-mesh addressing for region0 and region0 regions using cellVolumeWeight
    Overlap volume: 0
Creating AMI between source patch fuel and target patch fuel using faceAreaWeightAMI
    AMI: Creating addressing and weights between 40 source faces and 80 target faces
    AMI: Patch source sum(weights) min/max/average = 1, 1, 1
    AMI: Patch target sum(weights) min/max/average = 1, 1, 1
Creating AMI between source patch air and target patch air using faceAreaWeightAMI
Creating AMI between source patch outlet and target patch outlet using faceAreaWeightAMI
    AMI: Creating addressing and weights between 200 source faces and 400 target faces
    interpolating thermo:psi
    interpolating N2
    interpolating O2
    interpolating dQ
    interpolating CO2
    interpolating p
    interpolating CH4
    interpolating T
    interpolating H2O
    interpolating thermo:alpha
    interpolating U
End
The problem as you can see is the Overlap volume: 0
So, from original case only the boundary fields have been patched to the new case and not the internal fields. Then, do you have any idea what to do ?
Best regards,
Christos
panachristos is offline   Reply With Quote
Old   April 15, 2016, 12:19
Default Please any help???
I am still facing this problem. Anybody to help?
Old   April 16, 2016, 11:28
Retired Super Moderator
Bruno Santos
Quick question: Which specific OpenFOAM version are you using?
Old   April 17, 2016, 04:15
Dear Bruno,
Thank you for the reply! I am using 2.3.x version.
Old   April 17, 2016, 17:39
Bruno Santos
Quick answer: I believe this was a bug in OpenFOAM 2.3.x that was fixed in 2.4.x or 3.0.x.
Anyway, this worked for me:
mapFields ../counterFlowFlame2D -consistent -sourceTime 'latestTime' -mapMethod mapNearest
How I figured it out:
mapFields ../counterFlowFlame2D -consistent -sourceTime latestTime -help
Then:
mapFields ../counterFlowFlame2D -consistent -sourceTime latestTime -mapMethod a
and got this:
--> FOAM FATAL ERROR:
a not found in table.  Valid entries:
3
cellVolumeWeight
direct
mapNearest
Elham and panachristos like this.
Old   April 18, 2016, 04:22
Thank you Bruno!
This is a nice way to overcome the bug caused by cellVolumeWeight !!!
It works now.
With kind regards,
Christos
Old   April 18, 2016, 11:56
Actually I just found that mapNearest method does not patch ALL fields correctly!
For example, for this counterflowflame2D case it does not patch correctly the fields of p,alpha and psi !
Since, 2.3.x version looks to have many bugs regarding mapFields, i recommend to use another version for mapping e.g. 2.2.2, as already Philipp has mentioned in an older threat:
http://www.cfd-online.com/Forums/ope...-question.html
Thus, i followed his advice and the mapping was correctly done.
Old   June 30, 2017, 06:34
Andrea Ferrari
Andrea_85 is on a distinguished road
i know it is an old thread but i am having problems in using mapFields under openfoam 2.3.1. I want to map (only) the internal fields between two inconsistent geometries that overlap in a specific region, therefore i left the mapFieldsDict empty. Both cellVolumeWeight and direct method do not interpolate anything since they both return:
Overlap volume: 0
which is not correct
If i use mapNearest it gets stuck forever at this point
Creating mesh-to-mesh addressing for region0 and region0 regions using mapNearest
I tried to compile mapField 2.4.x under my version of openfoam but it does the same. mapfields 3.0.x or 2.2.2 do not complie under 2.3.1.
any idea about having a working mapFields under openfoam 2.3.1?
How did you compile mapFields 2.2.2 under 2.3.x?
Best,
Andrea
Andrea_85 is offline   Reply With Quote
Old   November 2, 2017, 21:40
Dominic
DominicTNC is on a distinguished road
I am facing the same problem as mentioned by Andrea. Using OF2.4.0, Overlap volume gives 0 if direct map method is used. If mapNearest is used, the program stuck forever at the same point.
P.S. My mapFieldsDict is empty also.
Any comments are appreciated. Thank you.
Dominic
DominicTNC is offline   Reply With Quote
Old   August 26, 2018, 21:27
Elham
Elham is on a distinguished road
Originally Posted by DominicTNC View Post
Dominic
Dear Dominic,
Do you remember how you could fix the problem? I am facing the same issue.
Cheers,
Elham
Elham is offline   Reply With Quote
HronTurekFsi tutorial case using icoFsiElasticNonLinULSolidFoam MarcelK OpenFOAM Running, Solving & CFD 9 February 25, 2019 02:25
Propeller case in AMI tutorial reza1980 OpenFOAM Running, Solving & CFD 68 November 28, 2017 21:37
[SOWFA] NREL SOWFA Tutorial case mohsen.boojari OpenFOAM Community Contributions 0 March 8, 2016 10:35
Cavity tutorial case shinde.gopal OpenFOAM Running, Solving & CFD 3 June 12, 2015 05:50
oscillatingInletACMI2D tutorial case for compressible flow jimteb OpenFOAM Running, Solving & CFD 0 February 6, 2015 05:17
