[Sponsors] | |||||
#21 | |
Rep Power: 12 ![]() |
I am sorry that I did not respond for such a long time, but I had to hand in my project. However, you are right: I use the steady state version so it is actually not the time, but the number of loop iterations. Quote:
What I did was simply to copy paste an old case, solved with buoyantSimpleFoam, change the solver in the controlDict and run it with mybuoyantSimpleFoam. In case of having an already solved filed from the buoyantSimpleFoam solver at loop number 300 e.g. my new solver saves fields for everything I want. But if I start a simulation based on the boundary conditions from the 0 folder, I do not get fields, only a file containing a value at the boundary. Like this for the viscosity: Code:
dimensions [1 -1 -1 0 0 0 0];
internalField uniform 1.01224393412375e-05;
boundaryField
inlet
type calculated;
value uniform 1.01224393412375e-05;
outlet
type calculated;
wall1
type calculated;
wall2
type calculated;
wire-upstream
type calculated;
value uniform 1.29521557667375e-05;
wire-north
type calculated;
wire-south
type calculated;
wire-downstream
type calculated;
top
type empty;
bottom
type empty;
Gerrit |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Fluent Tutorial on Heat transfer | Far | FLUENT | 15 | July 29, 2017 16:31 |
| Natural heat transfer in He tank with a heated rod inside | cltormar | CFX | 3 | January 16, 2015 18:59 |
| Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 19:53 |
| Heat Transfer mechanisms | tafaugl | CFX | 1 | November 7, 2012 19:46 |
| Heat Transfer Validation test case | Chris Whitney | Main CFD Forum | 1 | July 21, 1999 15:36 |
