June 10, 2016, 04:00 |
Dynamic mesh distortion
Rep Power: 10 |
This is a question I see has been posed previously without any resolution...
I have a simple 3D rectangular profile channel. The top face oscillates (pimpleDyMFoam, of 2.4) in the normal direction. It works fine in a 2D setup but in the 3D case distortion (severe non-orthogonality) results in divergence. Paraview shows that this is occurring close to the wall: since the wall is static the cells close by are effectively crushed as the top face oscillates inwards. Wondered if anyone has experience/suggestions for correcting this? As a first attempt I will try adding motion to the wall. |
June 14, 2016, 07:04 |
Rep Power: 10 |
So running with the extra dynamic BC on the walls (modified patches) does help; the case runs without crashing. There is a limit however to the amplitude to avoid cell crushing. The problem then requires use of layer removal for large amplitudes.
pimpledymfoam dynamic |
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
Dynamic mesh is not getting updated. | cardio | FLUENT | 1 | May 20, 2014 08:41 |
[ICEM] Dynamic mesh setup with ICEM | David121284 | ANSYS Meshing & Geometry | 0 | April 11, 2014 04:19 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 08:03 |
