Density-based, fully-coupled, compressible solver in OpenFOAM? |
January 24, 2012, 08:42 |
Francesco Capuano
Rep Power: 16 |
Dear all,
I would like to discuss and to share opinions with all you Foamers out there about the lack of a density-based, fully coupled, compressible solver in OpenFOAM. I've been studying OpenFOAM for about a month and, as far as I have understood, the only density-based solver (by "density-based" I mean that density is calculated from continuity equation) is rhoCentralFoam, which however solves the governing equations separately one from each other (in a so-called segregated way). All the other solvers are of pressure-based type. First of all: is this true? Second: how hard do you think it would be to create a new density-based solver, which solves the governing equations simultaneously (i.e. a coupled solver), provided with a robust upwind-like scheme such as Roe's or AUSM? Third: I have found, searching the Forum, that few years ago two Italian students developed a solver called aeroFoam http://www.cfd-online.com/Forums/ope...-aerofoam.html which apparently satisfies all the features that I mentioned. However, the solver has not been officially included into one of the OpenFOAM releases and the project has been apparently abandoned. Natural question: why? Hope the discussion will be constructive, Francesco |
January 24, 2012, 09:05 |
#2 | |
Chris Sideroff
Rep Power: 22 |
In addition, the rest of OpenFOAM would be need to made of aware of these new classes, e.g. the linear solvers. There has been some ongoing development in the -extend branch of OpenFOAM to add block coupled matrix classes. I don't believe a coupled N-S stokes solver has been built yet with it but I have seen work that uses it to couple other quantities. Dig around the last couple of workshops for material. So as you can imagine, the work is significant and non-trivial. |
January 24, 2012, 09:20 |
Francesco Capuano
Rep Power: 16 |
Dear Chris,
thanks for your answer. I realize the strong effort needed to extend OpenFOAM towards a coupled strategy. For those interested, the subject is studied in more detail in the following slides: http://www.openfoamworkshop.org/6th_...ord_slides.pdf On the other hand, I think that implementing an upwind-like flux scheme in rhoCentralFoam, for instance, should be much easier. Any experience/opinion? |
January 24, 2012, 09:55 |
Chris Sideroff
Rep Power: 22 |
One other effort of note is some density-based (segregated) solvers which include some more modern convective schemes, e.g. AUSM, etc, for turbomachinery in the extend repo:
http://openfoam-extend.git.sourcefor...urbo;a=summary I have seen very little documentation about it's use (presentatations or otherwise) but it's there for you to explore. |
January 24, 2012, 13:32 |
Francesco Capuano
Rep Power: 16 |
Very interesting, thank you very much!
July 11, 2017, 18:35 |
Di Cheng
Rep Power: 16 |
recently I transplant it to OpenFOAM 4.1. You can check it at https://github.com/chengdi123000/AeroFoamV1-2008.
as Chris Sideroff pointed out, foam-extend implemented block Matrix function. However, they did not offer how to implement block coupled solver. |
September 15, 2018, 10:26 |
Johan
Rep Power: 13 |
For a coupled, density-based solver, if you are using foam, have a look at
https://hisa.gitlab.io/ and https://sourceforge.net/projects/hisa/ |
November 20, 2018, 13:12 |
#8 | |
Deep
Rep Power: 8 |
This is interesting. I don't think so but can this use external sources through fvOptions? That'd be really useful for me if so. |
coupled solver, density-based |
density based solver and energy | ashka | FLUENT | 0 | May 3, 2010 05:46 |
regarding density and pressure based solver | Reddy | FLUENT | 0 | August 18, 2007 11:11 |
Pressure vs. Density based | jan | FLUENT | 2 | May 3, 2007 03:45 |
Solver and density function for high speed vapour | christian | OpenFOAM Running, Solving & CFD | 17 | April 12, 2007 02:41 |
Densitybased coupled compressible solver | jojo | OpenFOAM Running, Solving & CFD | 0 | July 19, 2006 12:43 |
