Where is the solve of UEqn in twoPhaseEulerFoam? |
July 5, 2012, 09:51 |
Qingang Xiong
Rep Power: 13 |
Hi Foamers,
In the manual "Derivation, Modelling and Solution of the Conditionally Averaged Two-Phase Flow Equations" by Weller et al. they said that momentum equations are constructed and solved. But in the solver code of twoPhaseEulerFoam, I just see UaEqn.relax(), not solve(). So could anyone explain to me how about this issue? Thank you! |
July 8, 2012, 10:51 |
bruce
Rep Power: 16 |
I think the momentum equation is not predicted and is only corrected in pressure loop which is conservative. (see pEqn.H)
July 9, 2012, 02:13 |
Alberto Passalacqua
Rep Power: 36 |
The momentum equation is defined (excluding some terms, which are transferred to the pressure equation), and the velocity is predicted with a single Jacobi step.
You could predict the velocity with a direct solution, including the transferred term by means of the reconstruct operator, however this might slow convergence down.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
June 3, 2019, 09:00 |
#4 | |
Siqi Ma
Rep Power: 6 |
could you please explain how to use a reconstruct operator? I am using twoPhaseEulerFoam(5.0) and have read some literatures about the solving process. As you said, the solver only predict the velocity rather than solve it... how could I get the value of velocity? thanks! It would be a lot of help. |
Bug in UEqn of twoPhaseEulerFoam? | cheng1988sjtu | OpenFOAM Bugs | 8 | August 26, 2011 06:45 |
solve continiuty for velocity | linch | OpenFOAM Programming & Development | 6 | June 30, 2011 04:04 |
Source term problem in UEqn of simpleFoam | fisch | OpenFOAM Programming & Development | 1 | June 17, 2011 10:57 |
Linearized NS euqations: how to solve them?(problem with Matrix operations..) | matteoL | OpenFOAM Running, Solving & CFD | 0 | November 18, 2009 06:58 |
How to solve another continuum and momentum eqn? | west_wing | FLUENT | 0 | August 25, 2003 10:00 |
